blown 383...
Old Feb 1, 2005 | 05:54 PM
black97z28LT1's Avatar
Question blown 383...
Ok i have a few questions here...first of of all, what is the compression on a 383? Because the lower the compression the better it is for boost right? And also is a 383 a good engine to have forced induction on? Im thinking about getting a 383 stroker with a procharger on it and i was just wondering if this would be a good setup? If not do you guys have any suggestions? Also what would it run me to rebuild my 350 to a 383 for all of you that have done it. Or would it just be better to just buy a new one.
Thanks, Zack
Old Feb 1, 2005 | 07:05 PM
kcshaner's Avatar
Re: blown 383...
383's don't come in a specific compression, that is all based on the pistons you get and how your heads are set up (gaskets, porting, etc.)
Old Feb 1, 2005 | 08:17 PM
1racerdude's Avatar
Re: blown 383...
Thanks, Zack
You can make a 383 anything you want with the right machine work,gaskets,heads,cam and pistons. Do the math.
Old Feb 1, 2005 | 08:25 PM
n2oblkz
Guest
Posts: n/a
Re: blown 383...
I am starting a 357 ci LT1 buildup for forced induction. I am planning on running about 15 to 18 ounds of boost and with my head and piston combo, I should have about 8.5 to 1 compression. That is right where I wanted to keep it at, so I think that it will fit me pretty well. If you start looking at some of the piston sites like www.jepistons.com and www.diamondracing.net, they have charts that show you about what compression your motor would have with a 3.75 inch stroke, 5.7 inch rod and whatever piston/cylinder head cc combo that you are wanting to use. SStrokerAce may jump in here since he is an engine builder an give you some advice but just search on here and check out how some of the other guys are doing their combos and it can give you an idea. Oh, and you will probably also hear to keep your cylinder over-bore to a minimum, like only go over .10 or .20. It keeps the cylinder walls thicker which you will want for a FI motor. I chose to still go with a .30 over bore since my car is just a garage baby, sunny day car. It will hardly ever see any track use but if I was building one for the strip, I would have used a .10 over bore.
RUENUF
Mar 13, 2016 03:39 PM
RUENUF
Mar 13, 2016 03:37 PM
Bxlt1
Sep 10, 2015 08:16 AM
blaze309
Sep 8, 2015 05:27 PM
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
