blowing out white smoke
Old Mar 27, 2007 | 05:41 PM
Executioner2k5's Avatar
what could cause this? the motor has 13k mile on it
http://s70.photobucket.com/albums/i8...t=S8000022.flv
URL Fixed
Old Mar 27, 2007 | 05:46 PM
STAYBG87Z's Avatar
Headgasket?
Old Mar 27, 2007 | 06:37 PM
95LT1conv's Avatar
that looks like a valve seal issue
Old Mar 27, 2007 | 10:14 PM
gitsum's Avatar
Do you have cats on it? Mine started smoking like that when I took them off.
Old Mar 27, 2007 | 10:19 PM
OBE1 95Z28's Avatar
Removing the cats won't generate smoke If it's white smoke, it's likely a head gasket. If it's blue smoke, you're burning oil. If it's black smoke, you're running too rich.
Old Mar 27, 2007 | 10:21 PM
Jazsun's Avatar
My car smokes white a little when its cold out and I start it up in the morning. I have no cats so I think condensation builds up where they used to be.
Old Mar 27, 2007 | 10:22 PM
That looks like blue smoke to me.
Old Mar 27, 2007 | 10:32 PM
c'mon is it blue or white lol help me! lol so i have either a blown head gastket or im burning oil what causes me to burn the oil?
Old Mar 27, 2007 | 11:04 PM
onephatZ28's Avatar
Bad rings
Old Mar 27, 2007 | 11:14 PM
Originally Posted by onephatZ28
Bad rings
and what causes bad rings? running the engine to hard, over heating, sh.itty rings used for rebuild? will i need to rebuild if this is the case?
Old Mar 28, 2007 | 01:21 AM
95LT1conv's Avatar
bad rings should smoke constantly. it appeared in the vid that the smoke clesred up after a few seconds which is most likely valve seals
Old Mar 28, 2007 | 02:46 AM
MARKTHOMASBRAND's Avatar
I would say that was definitely blue smoke,I had an '87 GTA that did the same sort of thing only it was much worse than yours.As mentioned it's probably valve seals if it just occcurs on cold start-ups.
Old Mar 28, 2007 | 07:49 AM
well i started my car like 10mins before that so not sure why it would still have all that smoke tho?
Old Mar 28, 2007 | 09:24 AM
OBE1 95Z28's Avatar
All cars, cats or no cats, will have condensation blow out the tail pipe until the system warms up. You think the old lady in the Accord in front of you removed her cats, yet here exhaust is blowing condensation out the tailpipe
Old Mar 28, 2007 | 10:06 AM
Jazsun's Avatar
Well, having gutted cats creates a kind of pool for water condensation which would normally be allowed to evaporate out the pipes normally but it gets stuck in the area where the cats used to be and trapped by the lip.
