blower doesn't always work? help
Old Feb 20, 2003 | 05:14 PM
JDMZ28's Avatar
when I first start my car and I turn on the heat it only comes out the bottom and the top but not the vent. When I put it on the vent setting it keeps blowing out the bottom and I can hear the controls hissing, like it wants to change to the vent but can't. What do you guys think it is?
Old Feb 20, 2003 | 06:22 PM
Blue89Bird's Avatar
broken vacuum hose. shoebox has some diagram for it probably, check out his site or do a search here, its fairly common.
Old Feb 20, 2003 | 06:25 PM
WheelmanZ28's Avatar
i agree, it's either a broken hose or possible a fitting that has come loose.
Old Feb 20, 2003 | 06:26 PM
mojo's Avatar
There is a little plastic "T" up near the firewall on passenger side with several vacuum lines on it-mine was cracked and doing the same thing yours is-if I recall,it is around $5.
Old Feb 20, 2003 | 06:49 PM
JDMZ28's Avatar
well there was a hose that I couldn't figure where it went. It's the one that comes from the same place the fuel lines do and wraps around the throttle body. Could that have something to do with it or is it something completely different?
MadMav
May 25, 2015 09:35 PM
eazyZ
Mar 1, 2015 07:12 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
1LEThumper
Jul 14, 2003 12:45 PM
