Blowby
Old Jun 15, 2004 | 01:16 AM
disco192's Avatar
Blowby
Ok so i think ive narrowed my problem to blowby.
The car idles REALLY rough and it sounds like air is being pumped through dry cylinders. The engine is sparking like it should, so i dont think its ignition related.
My instincts lead to blowby because i hear ALOT of noise comming from the PCV area which leads me to think there is alot of crankcase pressure.
I already replaced the PCV valve.
How would i test this and fix this?
Thanks Alot
Stu
Old Jun 15, 2004 | 05:07 AM
slopokrodrigez's Avatar
Use a manometer to check crankcase vacuum level. Pay attention to the instructions and the chart for each engine. If the vacuum level is low, then go with a leak down tester.
dizwiz24
Aug 10, 2012 09:36 PM
..DAMN..
Feb 4, 2009 10:43 PM
dre2013
Jul 10, 2008 10:24 PM
zbomb5610
Jan 21, 2006 01:26 PM
I8UR5OH
Classic Engine Tech
May 28, 2003 09:51 PM
