blow headgasket from wrong thermostat?
Old Jul 27, 2006 | 09:37 PM
D-BoZ28's Avatar
since the lt1 is reverse cooling, if you put a regular thermostat in it. would you blow a headgasket? what would the consequences be of this error? thanks
Old Jul 27, 2006 | 10:33 PM
Re: blow headgasket from wrong thermostat?
No, it should not cause blown head gaskets. You may or may not notice a difference. Some do, some say they don't. You should definitely run the correct LT1 thermostat, though.
Old Jul 28, 2006 | 04:15 AM
RE AND CHERYL's Avatar
I've heard installing the older style thermostat can cause overheating which could blow a head gasket in some cases.
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
blaze309
Sep 8, 2015 05:27 PM
