Blocking the timing chain cover hole used for the waterpump
Old Dec 20, 2005 | 05:22 PM
  #16
BlackScreaminMachine's Avatar
Re: Blocking the timing chain cover hole used for the waterpump
Oh and the JB weld idea sounds great to meach, cheap and inexpensive all the more better, 450$ for Morel lifters puts a hole in the funds
Old Dec 20, 2005 | 07:16 PM
  #17
sleepy_z28's Avatar
BSM, I run the Lunati and have had no problems at all and I spin mine up to 6800 rpm pretty regular. When my engine was tore down, we just removed the bearing and drive assembly for the water pump from the block and left the hole open. The hole in the timing cover was filled with a properly fitted freeze plug.
Old Dec 20, 2005 | 07:58 PM
  #18
Awesome thanks! that helps alot since you have a 383 and run nitrous like I will be.
Old Dec 20, 2005 | 08:33 PM
  #19
groundpoundinlt's Avatar
just a FYI: the lunatti chain is nothing but a stock GM timing set in a lunatti box..dont believe me, look at the part numbers on the gears and look them up on any GM site...second you can leave the gear stickin out of the timing cover...will work just fine and wont have to second guess the jb weld breaking, etc
Old Dec 21, 2005 | 07:11 AM
  #20
sleepy_z28's Avatar
My info has it that the gears are stock, but the chain is Lunati. I thought the same thing when I opened the box and saw the part numbers on the gears.
Old Dec 21, 2005 | 11:31 AM
  #21
To be honest I thought about reusing the set but if the lunati chain gives a little more assurance, I will go with it. I do not want to go to a vented opti, if at anything if i changed it would be a coil per cyl setup. Thanks for the help everyone, its always appreciated.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
