Is this block Toast? water damage...
Old Mar 24, 2011 | 09:02 PM
TANGltx's Avatar
Long story short... My engine took a dump and i got another one. I did some inspecting and found out a cylinder had a little bit of water. Turns out it went in through a exhaust port into the cylinder. I did some cleaning and Here's the damage...
Old Mar 24, 2011 | 09:10 PM
RamAir95TA's Avatar
Re: Is this block Toast? water damage...
Depending on how deep it is, it should be easily cleaned up with a bore.
Old Mar 24, 2011 | 10:28 PM
TANGltx's Avatar
It's deep enough to get a nail stuck. So if I were to put a good set of heads that i have Do u think it would hold compression? I don't want to take it to a machine shop.
Old Mar 24, 2011 | 10:31 PM
RamAir95TA's Avatar
Absolutely not. That will wreak havoc on the rings. The block is toast as-is, but it can be fixed.
Why don't you want to take it to a machine shop? It won't cost more than a few hundred to have it bored out and cleaned up.
Old Mar 24, 2011 | 10:59 PM
TANGltx's Avatar
Yeah that's what Ima have to do. I just didn't want to face the truth..jajaja..
Thanks for the input..
RUENUF
Mar 13, 2016 03:39 PM
willismoons
May 27, 2015 04:03 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
KYWes
Apr 15, 2015 07:28 PM
ad356
Apr 11, 2015 11:12 PM
