Block O-rings
Old Jul 17, 2004 | 09:08 PM
93ZM6Tally's Avatar
Block O-rings
I've got an o-ringed block and don't want to run a copper gasket. Is there anyone out there that has any experience using anything other than a copper gasket with an o-ringed block. Please tell me someone out there has done this successfully. I don't think that the o-ring groove could be removed by decking the block and I wouldn't want to take that much "meat" out of the deck anyways.
Help.
Old Jul 17, 2004 | 10:54 PM
Mindgame's Avatar
Jeez... that sucks.
Cutting receivers in the head... not too much problem but in the block....
They're going to be in there a ways.... probably .035 or so, so unless they cut em' without decking (highly unlikely) you can't go the "deck-til-clean" route.
It's a shot in the dark but maybe a call to FelPro will find you a solution. If you can get an accurate measurement on the OD/ID of the receiver groove, they might have a "loc-wire" gasket that'll work. If not, they can probably do a custom set for you at a price.
That, or you just go back to a copper gasket....
-Mindgame
Old Jul 18, 2004 | 09:06 AM
IrocSS85's Avatar
well, whats wrong with the coper head gasket w/wire setup? evenif its not nec. on your car, it will work still. I dont see how that reciever groove would make a standard gasket not work though. but Ive never had a reason to try it. I think a call to felpro or cometic would give you the answers you need though.
chris
Old Jul 18, 2004 | 09:37 AM
Mindgame's Avatar
Originally Posted by IrocSS85
well, whats wrong with the coper head gasket w/wire setup?[/b]
Well.... besides the fact that they usually leak, nothing.
[b]evenif its not nec. on your car, it will work still. I dont see how that reciever groove would make a standard gasket not work though. but Ive never had a reason to try it. I think a call to felpro or cometic would give you the answers you need though.
chris
If the recess overlaps the compression ring on the gasket, there's a good chance of compromising the seal. I agree with the suggestion to call the experts.
-Mindgame
Old Jul 18, 2004 | 10:22 AM
93ZM6Tally's Avatar
-Mindgame
Thanks man, that's exactly what I plan to do. Also found this company who's making a Rubber Coated Copper gasket that supposedly seals fluids better. Some of the LS1 forced induction guys are running them, maybe this is a possible solution. Gonna talk to these guys next week as well.
http://www.flatoutgroup.com/gaskets/techtips.asp
One way or the other I'll get it figured out.
GREEN3112
Feb 10, 2019 09:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
