Blinker Won't Blink?
Old Jun 2, 2003 | 03:41 PM
96BlackTA's Avatar
Question Blinker Won't Blink?
Lately whenever I go to make a right hand turn and put on my signal it dosen't seem to want to blink it just stays on steady... Anyone else ever have this problem??...solutions??
Old Jun 2, 2003 | 04:32 PM
americanmusscle's Avatar
Might want to check your break light bulbs on the right side. I could be one of them is burnt.
Old Jun 2, 2003 | 05:20 PM
kcsoz20's Avatar
Lightbulb
You might check the blinker fluid!
Ken
Old Jun 2, 2003 | 05:40 PM
Hawk's Avatar
Ken
damnit, u beat me to it. Thats all i thought when i seen this thread.
Old Jun 2, 2003 | 05:50 PM
nateh's Avatar
Usually when the signal stays on, it's a sign that some component has failed. If it's one side only, you probably have a bulb burned out, front or rear. I'd check that first.
Old Jun 2, 2003 | 06:09 PM
speedcrazy's Avatar
i had same problem 1 month ago. drivers side wouldn't blink just steady. all bulbs were good cause my hazards worked fine. replaced flasher and fixed problem. you would think if it was flasher both sides wouldn't work since drivers and passenger are controlled by same flasher. the flasher is like 2 bucks and its under your drivers side dash and takes 2 mins to change.
Old Jun 2, 2003 | 06:12 PM
Calli's Avatar
i had the same problem a while back and all the bulbs were good. Come to find out it was the ground wire had somehow worked its way out of the socket ... i reconnected that with some ingenuity and all has been well for some time now
Old Jun 3, 2003 | 12:22 PM
sp528's Avatar
It happened on both sides of my T/A. Both times it was just a loose ground wire. I kept that little blue clip off of the harness and that seemed to help. I tried the flasher unit and that did absolutely nothing.
68camaroboltz
Oct 5, 2015 01:46 PM
Hal Fisher
Sep 30, 2015 09:03 PM
KYWes
Sep 26, 2015 08:49 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
