Bleeding the fuel lines?
Old Oct 22, 2006 | 03:47 PM
TobyZ28's Avatar
I just put my stock injectors back in and am wondering if i need to bleed the air out of the fuel system? I never did this in the past, but just wondering if its bad not to...
Old Oct 22, 2006 | 03:54 PM
96flame's Avatar
Re: Bleeding the fuel lines?
Cycle the key a couple times to fill the fuel rail and fire it up.
Old Oct 22, 2006 | 03:55 PM
respectirocz's Avatar
any air in the fuel lines will either pass through the injector on start up or be forced back to the fuel tank through the return line
anytime a fuel line is disconnected, starting up is difficult immediately after, but after the vehicle starts up, it will start up everytime like it normally does
to speed up the starting process after disconnecting the fuel lines, prime the system by turning the key to the on position to turn on the fuel pump (automatically shuts off after 2 seconds). do this 2 or 3 times and then start the car
Old Oct 22, 2006 | 04:21 PM
TobyZ28's Avatar
Great, just wasn't sure if it handles the bubbles properly
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
