bleeding coolant
Old Apr 15, 2003 | 07:33 AM
chevy1963's Avatar
bleeding coolant
After changing the thermo will I have to "bleed" the coolant line? How do you guys suggest I do that. I know there must be an air pocket in there now? Thanks
Old Apr 15, 2003 | 07:40 AM
Depends on what procedure you use to change the thermostat. Have you done it, yet?
You can just check the bleed screws when the system is at normal temp and pressurized. That should get rid of your air.
Old Apr 15, 2003 | 07:43 AM
chevy1963's Avatar
I already changed to thermo to the 160. but I did it when the motor was cold, so I should just get the car to noraml operating temp and them use the screws to remove the air.?
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
1bad427ls1
Sep 23, 2015 01:12 AM
Bigtoyz97
Sep 21, 2015 01:44 PM
