Blackened Rocker...?
Old Nov 14, 2004 | 10:53 PM
Euclid's Avatar
Well, I got my motor back together yesterday. When I got home I decided to pull the valve covers off to readjust the rocker arms just to be safe, and I was pretty stumped with what I found!
One of my rockers was completely black. As the motor ran, it got absolutely no oil up through the pushrod.
What could the problem be? Tomorrow I plan on taking out the pushrod and making sure there is no debris in it. If that isn't the problem, what could it be?
Any suggestions/ advice are appreciated. Thanks!
Old Nov 14, 2004 | 11:05 PM
Spinner's Avatar
Re: Blackened Rocker...?
Could be a bad lifter.
Old Nov 14, 2004 | 11:11 PM
Euclid's Avatar
They're brand new. *shrug*
Old Nov 14, 2004 | 11:32 PM
Spinner's Avatar
Which makes even more sense. Sounds like a defective lifter.
Old Nov 14, 2004 | 11:58 PM
Euclid's Avatar
Could I just replace that one with one of my stockers?
Old Nov 15, 2004 | 01:48 AM
slimdawson's Avatar
If the new lifters that are in there are stock, then yes. If not, I would like to put the same back in. I can't see buying aftermarket lifters that aren't needed, so I assume the rockers that are in there are needed. I see you have a cam. What kind of lift and how high do you spin it.
Do check to see if the pushrod is clogged. I also wouldn't run it until that problem is fixed.
Good luck.
Old Nov 15, 2004 | 10:52 AM
Euclid's Avatar
They are the ones that come with the LT4 kit. My cam is a 230/236 .544/.555 and I spin it to 6400.
Old Nov 15, 2004 | 11:12 AM
slimdawson's Avatar
Are they gm pieces then? I would see if you could buy one single lifter from gm.
By just looking at the cam and revs though, I would say you could use stock lifters.
Old Nov 15, 2004 | 05:52 PM
blown94's Avatar
Being that the lifter is probably bad and all, is it possible he f'd up the cam lobe too?
Old Nov 15, 2004 | 06:03 PM
Dave89IROC's Avatar
cam should be ok, if/when you pull the lifter, look/feel the roller, it should be smooth and roll freely, if it does, look in the lifter bore at the cam lobe, if it looks good, your cam is fine
Old Nov 15, 2004 | 07:24 PM
Euclid's Avatar
Yeah, it's the lifter's fault. The pushrod and rocker have no blockage at all. There's no way to pull the lifter out with the intake still on, is there? What a PITA.
Old Nov 15, 2004 | 07:29 PM
Spinner's Avatar
Nope, gotta pull it off unfortunately. Hopefully your cam is alright
Old Nov 16, 2004 | 12:33 AM
Euclid's Avatar
Hmm. I swapped the rocker/pushrod and another cylinder's and the problem is now fixed. What gives? Problem fixed, w00t w00t!
Old Nov 16, 2004 | 08:15 AM
Spinner's Avatar
So you swapped that rocker to another cylinder? I dont know if thats the best idea, if it got black, it got hotter then I care to think about, and who knows how long it's going to last?
Old Nov 16, 2004 | 07:49 PM
Dave89IROC's Avatar
seconded, If it got hot enough to get black, it got hot enough to lose the heat treatment
