Blackened Rocker...?
Well, I got my motor back together yesterday. When I got home I decided to pull the valve covers off to readjust the rocker arms just to be safe, and I was pretty stumped with what I found!
One of my rockers was completely black. As the motor ran, it got absolutely no oil up through the pushrod.
What could the problem be? Tomorrow I plan on taking out the pushrod and making sure there is no debris in it. If that isn't the problem, what could it be?
Any suggestions/ advice are appreciated. Thanks!
Re: Blackened Rocker...?
If the new lifters that are in there are stock, then yes. If not, I would like to put the same back in. I can't see buying aftermarket lifters that aren't needed, so I assume the rockers that are in there are needed. I see you have a cam. What kind of lift and how high do you spin it.
Do check to see if the pushrod is clogged. I also wouldn't run it until that problem is fixed.
Good luck.
Good luck.
Originally Posted by blown94
Being that the lifter is probably bad and all, is it possible he f'd up the cam lobe too?
Yeah, it's the lifter's fault. The pushrod and rocker have no blockage at all. There's no way to pull the lifter out with the intake still on, is there? What a PITA.
Hmm. I swapped the rocker/pushrod and another cylinder's and the problem is now fixed. What gives? Problem fixed, w00t w00t!
Originally Posted by Spinner
So you swapped that rocker to another cylinder? I dont know if thats the best idea, if it got black, it got hotter then I care to think about, and who knows how long it's going to last?
