biggest valve size for LT1 heads?
Old Sep 6, 2003 | 01:59 AM
96LT14u2Nv's Avatar
im pulling my stockers to get a stg2/stg 3 port job done.
i am going to get a 3 angle valve job,port work and was wondering what the biggest valves i can put in them would be. thanks
what would a good stg.2/3 head porting job consist of?
Old Sep 6, 2003 | 07:46 AM
FastZinTennessee's Avatar
You can run 2.02 x 1.60, but they overlap the seats and don't give a gain over 2.00x1.55 valves, which is what I'm using.
I'm not sure how they rate the stages, but I think what you're looking for is a full port of the ports, runners, bowls, and chambers, larger valves, three angle job, milled for higher compression etc.
John
Old Sep 7, 2003 | 02:52 AM
96LT14u2Nv's Avatar
thanks for the info
Old Sep 7, 2003 | 04:40 AM
AndyB's Avatar
However 2.02 valves fit just fine in the ImpalaSS Iron heads
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
