biggest, nastiest cam for stock heads
Old Jan 23, 2007 | 04:15 PM
Texas_96_Z's Avatar
Ok so I have decided the next major mod will be cam and valvetrain. So my question is: What is the nastiest cam I can run with my stock (will be ported later) heads? This is a weekend car so I don't care about gas milage, ect. This will be a slow parts build up (married with kids). So LE1, 2, 3 or custom grinds are not feasible at the moment. Remember, I will port the heads later on down the road.
Thanks in advance for your replies.
Old Jan 23, 2007 | 04:21 PM
blackztpi's Avatar
have bret bauer make you one....I'm sure he can get one pretty nasty for you
Old Jan 23, 2007 | 06:27 PM
Texas_96_Z's Avatar
I was thinking of an off the shelf cam.
2000GTP's Avatar
GM847 maybe?
Old Jan 23, 2007 | 06:30 PM
roadtrip120's Avatar
go with a BRE (Bauer Racing Engines) custom grind all the way, he can match it exactly to your setup, ( weight, rpm range, gears, flow number of heads, everything)
Old Jan 23, 2007 | 07:25 PM
Texas_96_Z's Avatar
I would like to go the BRE route but I have to piecemeal the project over time. Remember I will not be able to do any headwork for a long while, the cam and valvetrain will have to be used with the stock heads for a long while. So how does the GM847 act with stock heads? Will it be choked down too much with my current set up? I do not want to spin the bottom end too much and jack up my bearings. The "When are you going to sell that" would be unbearable.
Old Jan 23, 2007 | 07:30 PM
mdacton's Avatar
I wouldn't waste your time going with a big cam.... go with a 503 or something. A proven winner...that will make more power than a BIG cam that will run like crap and be slower than other cars. Cams need to match the package i.e. you get the new heads you get a new cam
I'm putting it this way b/c I have made all of these mistakes before
Old Jan 23, 2007 | 07:36 PM
blown383's Avatar
I have a Comp Cams 236/242 ground on a 110 lsa with the valve springs to match. Thats as big as you can get unless you go solid roller. $250.00 plus shipping and its yours.
-B
Old Jan 23, 2007 | 07:47 PM
mdacton's Avatar
I have a 256/266@.050 hyd. bullet on a 108
Old Jan 23, 2007 | 07:58 PM
seawolf06's Avatar
Bigger is not always better.
Old Jan 23, 2007 | 08:13 PM
chrism400's Avatar
OMG! That's insane!
Old Jan 23, 2007 | 08:19 PM
mdacton's Avatar
yeah thats why i haven't used it...YET
no honestly a camshaft is the brain of your engine...not the computer, a bunch of mismatched stuff=slow junk that runs like crap and you never get it right...i've been there too many times, I ran a 240@.050 cam in a stock 305 motor it runs like crap etc. turns sky hi and went to another cam a little smaller and the car went 108m.p.h first time at the track
just sit back and see what others have done and what works good...R&D and you will be miles ahead
Old Jan 23, 2007 | 08:50 PM
Texas_96_Z's Avatar
Ok lets get down to the nitty gritty:
1) 503
2) 306
3) XE 224/230
What do you boys think is the best for my situation and why?
Old Jan 23, 2007 | 09:23 PM
Javier97Z28's Avatar
Moderator
1) 503
3) XE 224/230
Same thing.
I'm not a big cc306 fan.
Old Jan 23, 2007 | 09:47 PM
speed_demon24's Avatar
What does having stock heads have to do with not doing a custom cam? Custom cam, $300, more power and better area under the curve, or spend $270 and get a cam that isn't matched to your combo.
