Bigger throttle body on a bolt on car
Old Aug 15, 2007 | 01:49 AM
exgmguy's Avatar
First off, I did a search on this and it seems pretty split down the middle. Most of the threads are old as dinosaurs too.
So, I have a bolt-on car with an automatic trans that last ran 105 mph in the 1/4. The basics are headers/exhaust/CAI/1.6 rockers...... I am wondering if switching to a 52mm throttle body would be worth any gain at all. I consider 4-5 rwhp worth doing it.
Thanks,
Rob
Old Aug 15, 2007 | 02:01 AM
nickp's Avatar
I bolted on a 52mm bbk tb. At that time my car had a c.a.i., off road pipe in place of cat, hypertech tuning, and flowmaster replacment muffler. I only gained 1 mph through the traps and a about 1 tenth (e.t.) consistantly. The more bolt ons you have the more it will benefit your set up.
Old Aug 15, 2007 | 02:04 AM
RedLT4Mike's Avatar
Spend your money elsewhere
Old Aug 15, 2007 | 08:38 AM
exgmguy's Avatar
That is also what people said about an underdriven crank pulley, but it netted almost 1 full mph at the track. If it is worth 1/10th in the 1/4, why not?
Old Aug 15, 2007 | 01:12 PM
2000GTP's Avatar
The larger throttle body might net you a couple of extra horsepower. If that is worth the cost, then by all means. The money would probably be better spent elsewhere. Have you already done a PCM tune?
Old Aug 15, 2007 | 01:15 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Get a torque converter instead
Old Aug 15, 2007 | 04:21 PM
Irish350's Avatar
yeah, a stall (or gears) will do you more good than a TB, but it is one of the basic "support bolt ons" that youd want if you went FI or something like that
Old Aug 15, 2007 | 05:11 PM
exgmguy's Avatar
I've already done a converter and a MadZ28 chip . About all I have left is an electric water pump.
Old Aug 15, 2007 | 05:12 PM
2000GTP's Avatar
Or a pair of drag radials, done.
Old Aug 15, 2007 | 05:22 PM
TobyZ28's Avatar
I say go for the TB, the gains may not be the most cost efftive early on but your near the end of the bolton phase Your next step up will be heads/cam and if/when you do go that route you'll already have the TB
Old Aug 15, 2007 | 05:31 PM
Irish350's Avatar
its also really easy to put on
Old Aug 15, 2007 | 06:12 PM
Okay then do the EWP, gears, and some DR's
lt1-xjs
Jan 17, 2015 07:52 PM
CARiD
Dec 26, 2014 04:20 AM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
