Ground wire question, please help
Old Aug 15, 2007 | 04:24 PM
dr97z's Avatar
There's a ground wire that bolts to the block next to the dipstick from what I understand, do any of you guys know exactly where that leads up to, because I think mine is missing.
Old Aug 15, 2007 | 04:32 PM
Daniel6718's Avatar
what gauge? big 8 gauge goes to the mm bolt...small ground wire goes to a stud on the pan i believe?
Old Aug 15, 2007 | 04:38 PM
dr97z's Avatar
Yeah, I know the ground wire goes to the bolt on the block, but where does it lead up to, somwhere by the PCM I was told.
Old Aug 15, 2007 | 04:39 PM
lethal93ta's Avatar
mine the battery ground went to the engine mount and theres a small braided line that went to the body.
Old Aug 15, 2007 | 04:53 PM
It goes to the PCM.
Old Aug 15, 2007 | 05:05 PM
FASTFATBOY's Avatar
It is a little wire with a 1/4 inch ring terminal,Looks almost identical to the small starter wire, I put a studded oil pan bolt near the motor mount and put it there.
David
Old Aug 15, 2007 | 06:49 PM
Dave89IROC's Avatar
http://shbox.com/1/g103.jpg
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
Injuneer
Dec 15, 2014 09:36 AM
Jul 4, 2005 05:00 PM
kandied91z
Aug 6, 2002 01:18 AM
