Big LT1
Old Dec 2, 2005 | 06:10 AM
Black Cloud's Avatar
Big LT1
What is the largest CUIN Lt1 can I build?And how do I get there?Bore,Stroke,etc.My car is drag only so I can fill the block if needed.
Any help is greatly appreciated.
John
Old Dec 2, 2005 | 06:13 AM
IllusionalTA's Avatar
Re: Big LT1
i've seen 410's but i think that's about as big as i'd go on a stock block.. Lot's of clearancing in the lower half and a decent oversized bore...
Old Dec 2, 2005 | 08:34 AM
96capricemgr's Avatar
Re: Big LT1
Also looking at sonic testing a few blocks to get there.
My advise would be just stick to 383/396 and sinke all the money you were prepared to spend going big cubes into the heads. If really looking to spend big money on the project look at gen1 altered angle heads there is more potential there than the available LTX castings, conversion to reverse flow usually costs somewhere around $500 then you need to figure out what to do about an intake.
Old Dec 2, 2005 | 08:39 AM
Re: Big LT1
There's someone that used to post here that sleeved the block for 427ci. There is another individual who is long gone, who built two different versions of a 421ci LT1.... 4.030" bore x 4.125" stroke, and 4.090" bore x 4.000" stroke. Big $$$$$
Old Dec 2, 2005 | 10:17 AM
Re: Big LT1
Please explain how to make heads to work?I'm running a carb intake.
Old Dec 2, 2005 | 02:41 PM
97WS6SCharged's Avatar
Re: Big LT1
In a nutshell you drill the extra cooling holes in the heads and then resurface them.
If it's a race car, why limit yourself to an LT1 based engine? They make aftermarket K members for small block swaps, LSx swaps, and even big block swaps.
Old Dec 2, 2005 | 05:38 PM
1racerdude's Avatar
Re: Big LT1
Put a 732" BB in it. The cost is about the same.
Old Dec 2, 2005 | 07:11 PM
Re: Big LT1
Yeah, a mild 732 cid rat with just 1.4 hp/cid.
MadMav
Feb 6, 2015 11:02 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ddr698
Jan 9, 2015 10:05 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
ChrisFrez
Nov 30, 2014 08:41 AM
