Big cam, and low brakes vacuum...
I put a big cam on my Z28, and as I was expecting, my brakes were going to suffer a bit. So, what are you guys doing to fix this?
I've seen a vacuum reservoir sold by Summit Racing. What you guys think of it?
Anything you guys can recommend?
I'm going to upgrades my brakes to a Baer Kit, but even with that kit, I think the lack of vacuum may still be a factor.
Thanks-Goose
Thanks-Goose
I did a Google search, and I found this one by Crane Cams...
http://www.cranecams.com/pdf/99590.pdf
...and this one by Summit Racing...
http://store.summitracing.com/productdetail.asp?p=1838
Originally posted by madwolf
How big? I have a 233/239 and the brakes work fine. I did tweak the closed throttle timing tables a bit though.
I'm having the car dyno tuned in a couple of days, right now, I'm taking it easy on the break-in. The brakes have gotten a bit better, but not much. That's why I wanted to see what you guys are doing about it, if in the same situation as I am.
Thx-Goose
bossco
Nov 29, 2014 10:18 AM
