Which is better H or I beam rods?
Old Oct 27, 2003 | 04:00 PM
Naegash's Avatar
Within the next few months I will be rebuilding my motor. I'll be ordering most if not all of the parts needed form cmotorsports. Right now I'm thinking about their $1749 383 stroker kit. Only question I have is about rods, should I go with the Eagle H beam or some sort of I beam rod? Thanks for any light you guys can shed on the situation.
Old Oct 27, 2003 | 04:04 PM
gb95zconv's Avatar
H beams are stronger....I belive they are rated up to 700fwhp
I beams are rated to 500hp. Thats speaking of the Eagle H and I
Old Oct 27, 2003 | 04:17 PM
flyinZ's Avatar
I went with the Eagle H-beam forged rods.(6")....
Old Oct 27, 2003 | 04:21 PM
Naegash's Avatar
Did you have to go with an aftermarket oil pan? I was already thinking about doing this anyway because I would like to have the extra oil capacity.
Old Oct 27, 2003 | 04:24 PM
rskrause's Avatar
Moderator
There are good (and bad, and indifferent) rods of each type. Impossible to generalize. FWIW, F1 is the pinnacle of automotive engine tech and the last picture of an F1 rod I saw, it was an I-beam type configuration, FWIW. I have used both with good results.
Rich Krause
Old Oct 27, 2003 | 04:30 PM
lfish's Avatar
I-Beam gives a little more clearance if youre really stroking it out. My engine builder had me go with I-Beams with my 396. Said H-Beams would be cool with a 383, but to go I-Beams with the 396. Went with the 5.85 Lunati Pro Mods.
Larry
Old Oct 28, 2003 | 06:36 AM
IDOXLR8's Avatar
I currently have Oliver I-beam rods and am making over 700 rwhp with out any problems.
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
realistyc
Jul 28, 2015 07:32 PM
