Better flowing Y-pipe for Pacesetter LTs?
Old Nov 12, 2006 | 01:41 PM
JP95ZM6's Avatar
The Pacesetter Y pipe has a simple tube intersection, so the left and right exhaust streams 'crash' into each other rather than merging together smoothly. This does not seem to be as good for flow as a 2-1 merge style, like the Kooks or Mufflex Y-pipes have. I don't know how much the merge design affects power.
I can't find the better 2-1 merge style with slip fit connections to fit the Pacesetter headers. Does anybody know if one is available, or if one of the 2-1 merge Y-pipes can be modified to work to work with the Pacesetters? I want the slip fit for ground clearance.
To make it easy to compare, both styles can be seen here:
http://www.hawksthirdgenparts.com/in...S&Category=603
Thanks.
Old Nov 12, 2006 | 04:01 PM
2000GTP's Avatar
I haven't seen an off the shelf off-road y-pipe that will cater to the slip-fit Pacesetter headers. If you want something with better flow, you may have to have it custom made.
Old Nov 12, 2006 | 07:53 PM
My Iroc Z28's Avatar
I always thought about cutting off the end of my y-pipe and putting this flowmaster merge in there to see if there would be any gains. But with the idea of true duals floating around my head im not sure if i will ever get it done!
http://store.summitracing.com/partde...0&autoview=sku
They make them in 3'' but you have to call summit for the part number. I had it somewhere but cannot find it.
Old Nov 12, 2006 | 09:13 PM
JP95ZM6's Avatar
According to a PM today from Sean at Speed Engineering, they don't have a picture of the actual Pacesetter Y. However, he answered my question:
'PaceSetters Y-Pipe is a 2/1 equal merge though. '
So, the Pacesetter Y DOES have the 2-1 merge. Excellent. Problem solved. One more thing to like about the Pacesetter products. Although, that means 95% of the pictures for that Y-pipe that I found fin catalogs on the web are wrong. I hope Sean was right, I just gave him my order. Good price.
Old Nov 13, 2006 | 09:36 AM
Colin91Z's Avatar
Here's some pics of my pacesetter y-pipe for future reference
Old Nov 13, 2006 | 09:59 AM
JP95ZM6's Avatar
Hey, thanks for the pix! That is the welded tube style, NOT the parallel 2-1 merge like Mufflex has. Dangit, Sean from Speed-Eng misled me and I ordered last nite! I should have known that 95% of the pics on the web are CORRECT. But I trusted him.
I would have bought the headers from somebody anyway, but I'm not pleased that Sean evidently either didn't take the time to understand the question, or didn't know what he is talking about and didn't bother to look at the photo links. I would have bought from Texas Speed had I caught this earlier. It was hopefully an honest mistake, but very sloppy. Hmmm. I still have another $4K of parts left to buy......someplace.
Old Nov 13, 2006 | 10:59 AM
JoeliusZ28's Avatar
I wouldnt worry about the "crashing" effect much. I have a custom 2.5" y-pipe behind my pacesetters that crashes together and it works just fine.
actually ive got a vid of it if. header clips are about halfway through:
http://videos.mifbody.com/video/bc52...76017293da.htm
Old Nov 13, 2006 | 11:51 AM
I was gonna post last night that he was wrong but wanted to be sure before i did. Ive heard that changing the merge can gain 10hp.
Old Nov 13, 2006 | 12:10 PM
JoeliusZ28's Avatar
if anyone can back that up ill seriously look into changing mine!
Old Nov 13, 2006 | 05:38 PM
JP95ZM6's Avatar
Well, in a couple of months when I have the car back together, I'll mock this up under the car and see what it takes to install a better merge. Looks like 2 new 45* elbows, installed a few inches upstream of the original welded joint, could give me the 2 parallel tubes needed to use a 2-1 parallel y-collector. Like Jegs p/n 389-Y250300A. The inlets on that one are 2.5", though, so that exact part won't work.
If somebody can substantiate the 10HP, I would even take the time to make a custom Y.
Formula Steve
Sep 19, 2023 08:31 AM
GREEN3112
Feb 10, 2019 09:19 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
