best way to wire a csi electric waterpump, I see several.
Old Jun 17, 2003 | 05:30 PM
yorkie's Avatar
icm power to trigger relay, fuel pump to trigger it? Air pump relay to trigger it (since mine is deleted.??
Old Jun 17, 2003 | 06:33 PM
97FormulaWS-6's Avatar
I'm using a seperate 30A relay that's powered directly fom the distrubution block on the PS fender. I'm triggering the relay with the Fuel Injector fuse/relay in the under-hood fusebox.
Old Jun 17, 2003 | 09:51 PM
yorkie's Avatar
any links?
anyone??
Old Jun 17, 2003 | 10:14 PM
Kuma's Avatar
Try this:
http://ken.lowrance.com/projects/CSI...mp/default.htm
Good luck, let us know how it turns out...
Old Jun 17, 2003 | 10:17 PM
yorkie's Avatar
thanks I had found another site
that used the air pump relay if the air pump has been removed.
Sergio
Jan 27, 2016 04:27 PM
HarleyZ28
Oct 5, 2015 06:23 AM
lbrowne
Nov 13, 2011 04:25 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
