best way and things to do to store car for 4 months?
Go
Ok, im gonna be storing my car in a non heated garage starting in about a week until about March. what are some of the things I should do to get it ready to be stored??? I think i will have my dad go out and start it every now and then while im gone. Any help is greatly appreciated.
________
Lorenal cam
________
Lorenal cam
Also...
Add Stabil to the fuel to keep it from rotting. Some guys run SeaFoam in the intake until it stalls out and then leave it like that with the SeaFoam in the intake and on the back of the valves.
I change the oil so it's fresh, then drive it into the garage and turn off the engine and disconnect the battery. That's it. Never had problems at all the last 6 years. Always starts up fine in the spring and runs like a champ. I do use synthetic oil, which I heard stays coated better over long periods. Don't know if that's true or not.
Dan
Dan
Some what like storing a boat inboard motor. Stabil into the gas tank, fog the engine to prevent rust on the cly. bores & valve stems. Oily rags into tail pipes, alum. foil over air cleaner to close it off. This is recommened for any engine that will not be run for more than 30 days. I also put a sheet of plastic under the whole car as a vapor barrier, & use a car cover. But I also start & drive the car up & down the drive every week to keep the A4 & tires "moving" if you do this you won't have to fog the motor or remove the battery. AND the clutches in the A4 won't dry out. It's up to you ......
NewsBot
Dec 3, 2014 12:30 PM
Hal Fisher
Sep 14, 2002 09:36 PM
