Best way to remove a broken manifold bolt?
Old Mar 21, 2004 | 07:46 PM
Black94mula's Avatar
I removed the driver side manifold today and the bolt to the right of the #5 primary was broken. The head was still sitting in the hole in the manifold but must have broken awhile ago. Whats the best way to remove this damn thing without having to remove the head?
Old Mar 21, 2004 | 07:52 PM
Z95m6's Avatar
if the bolt didn't break off flush with the head i would try to get some vice grips on it.
Old Mar 21, 2004 | 07:56 PM
scooters97ss's Avatar
Weld a 3/8 flat washer to what is left of the bolt. Just hold the washer flat against the head and weld in the center hole; then weld a nut to the washer and it should spin right out.
nah, no chance of vise grips..
Old Mar 21, 2004 | 08:14 PM
We must have posted at the same time. Try what I said above. I have done it literally hundreds of times with great success. I work in an exhaust shop.
Old Mar 21, 2004 | 09:07 PM
I'm sorry, I don't seem to understand what your saying. There isn't anything sticking out either. kinda broke off in the hole....if not in the hole, then flush.
Old Mar 21, 2004 | 09:11 PM
94zLT1's Avatar
mine broke off flush in the head and i tryed to use a drill bit and then extract it and broke off the extractor in there too...ha...so i drilled a hole in my header to match up with the inner bolt hole in the head and will bolt in there..see my domain pg.6 for pics..they go in tommarrow
Old Mar 21, 2004 | 09:15 PM
marshall93z's Avatar
i like the washer and nut welding idea...im going to try that on mine.
Old Mar 21, 2004 | 11:23 PM
94-3.4's Avatar
So what do you do when the bolt is a good inch in the block? Any ideas? Just wondering how i am gonna get my broken optispark bolt out
Old Mar 22, 2004 | 12:02 AM
JJ's95B4C's Avatar
the opti spark bolt shouldnt be very tight. I would get an extractor kit at your local auto part store(the one with a drill bit and a reverse threading tool). It should work fine, just drill down the center of the bolt. Check the length of the other ones to make sure you don't drill too far and into the block.
DirtyDaveW
Dec 1, 2016 05:37 PM
maybe2fast
Mar 16, 2015 09:45 AM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
Jul 4, 2005 05:00 PM
