Best way to make 350-400 RWHP?
Old Oct 30, 2003 | 09:12 PM
  #16
AustinZ28's Avatar
Originally posted by dnz28
well I guess a 350-400 hp monster is just fine for a daily driver. I was just tring to get think of a cam for both situations. well any ways heads and cam are almost automtatic 350-400hp. my set up was dynoed at 385. so if you take a look in the sig that should put you where you want. glad you like the springs. You like the drop?
Cool. Yes I love the drop the car looks so much better lowered. The springs are great, the ride quality is the same or better than stock. I however replaced my shocks and struts at the same time. I think all cars look good lowered. Except my Jeep. ------> Brad
Old Oct 30, 2003 | 10:23 PM
  #17
dobe's Avatar
Originally posted by AustinZ28
Thanks for the advice but my Dad can most likely make mine flow better and it will be free.
thats good hope daddy makes you happy
Old Oct 30, 2003 | 10:30 PM
  #18
TreySpeed's Avatar
On permanent vacation
assuming his dad is a good porter, the money he saves in labor can be used for better castings and maybe even a 15* conversion.
its all aobut the bucks!
Old Oct 30, 2003 | 10:51 PM
  #19
RedPhenx's Avatar
what advice has your dad given you exactly?
Old Oct 31, 2003 | 07:13 AM
  #20
AustinZ28's Avatar
Yeah he will. My Dad had never been that great of a Dad to me, but he knows how to build a motor. Eveyone around Austin knows about his work. He just finished building a 1000+hp 2jz Supra motor. He already built my friends 740 hp SC Corvette engine. He does all the machining work for Protech now. He is really good at what he does. Oh and he has a flow bench. Not trying to brag or anything, I just know he is good at what he does for a living ---> Brad
Old Oct 31, 2003 | 07:15 AM
  #21
AustinZ28's Avatar
Well, I think he is hesitant about making the car really fast. Probably cares about me or something...... So when I ask him what to do to make my car fast, he kind of BSs with me and tells me to see what others are doing for street cars. -Brad
Old Oct 31, 2003 | 08:36 AM
  #22
Bersaglieri's Avatar
Question Tame Cam and High lift heh?
Originally posted by TreySpeed
..define "best"
the word LT4 comes to mind if you mean best in a tame way.
Lots of head, tame cam, high lift, full bolt ons and you should have no problem making above 400rwhp and barely loping.
My idea of "best" for a street car is as tame as humanly possible, a low reving as humantly possible, as reliable as humanly possible while still meeting my goals.
Id rather spend an extra $500-$700 to get it tame and lower reving.
I am as intested as Brad to hear what kind of set up Trey thinks would be the best humanly possible. My goals are similar or the same as Brad's and I want the same aspects you are speaking of. Not trying to pull a hijack but I just want to hear Trey's opinion. Sounds like your going in the right direction for Austin as far as reliablity since he doesnt want to start breaking anything. Especially on a daily driver. Thanks.
Just looking for a goal to start working towards, thanks.
Dustin
Old Oct 31, 2003 | 08:57 AM
  #23
BradZ28's Avatar
Have your dad port/polish/3-angle valve job/mill your heads. The next most important thing is the cam choice. Good choices are:
Comp Cams (big)
cc306
XE 230/236
Comp Cams (medium)
XE 224/230
cc305
GM Cams
GM847 (big)
LT4 Hotcam (medium)
All of these can make 350RWHP and the big ones can make 400RWHP or over....
Also you will need long tube headers, Y-pipe or true duals, 1.6RR and springs to match the cam (Combonation Motorsports has good packages). Don't forget about a PCM reprogram, bigger injectors, and gaskets, ect.
Old Oct 31, 2003 | 09:17 AM
  #24
gritter's Avatar
So what i gathered from reading this is. Port the heads.Get a new cam,LT's. Y pipe,cai,exhause,1.6 rr's and he should be neaar 350 rwhp?
Old Oct 31, 2003 | 03:27 PM
  #25
Rival's Avatar
with a good porting job and one of the big cams you'll be at 400rwhp. Don't forget lifters and pushrods. If you go with the 224/230 or 305 and ported heads you'll be around 380rwhp. Good luck
Old Oct 31, 2003 | 03:45 PM
  #26
DamianLT1's Avatar
Are you worried about emmission? Cause I don't think a CC306 will pass emmission.
Old Oct 31, 2003 | 05:07 PM
  #27
TreySpeed's Avatar
Re: Tame Cam and High lift heh?
Dustin
best to me is probobly an NA setup (cost reasons)
Combination motorsports stage III heads, a good 396 if applicable and needed, High lift, relativly short durration cam, long tubes and probobly a hooker catback and so forth. Thats just my idea of a good daily driver.
...and dont forget the dyno tune@!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
jmzlt1
Mar 13, 2003 07:26 AM
