best way to drain coolant without making a mess?
Old Aug 23, 2007 | 07:33 AM
sabre81's Avatar
What are your tricks to accomplishing this?
Old Aug 23, 2007 | 09:04 AM
wrd1972's Avatar
If you are talking about COMPLETELY draining thre block then I doubt there is any clean way. I just pull the knock sensor and then hose it off.
Old Aug 23, 2007 | 09:07 AM
joeSS97's Avatar
There is a drain plug on the other side ,across from the knock sensor.Drain both of these and your radiator and you are good to go.
sabre81's Avatar
Well not completely. Just enough to change a water pump.
Old Aug 23, 2007 | 09:08 AM
joeSS97's Avatar
If you are just doing the WP,drain the radiator...You will still get some out the bottom bolt on the pump,have rags handy.
Old Aug 23, 2007 | 09:16 AM
sabre81's Avatar
i've done it 4-5 times and i always make a mess. It angers me.
Old Aug 23, 2007 | 09:32 AM
Z28LT1_Just_Nasty's Avatar
I've done it about 4-5 times as well and there is never a clean way to do it. Always get a mess no matter what I do.
Old Aug 23, 2007 | 10:30 AM
NotACop97z28's Avatar
Get the biggest drip pan you can find, and put one of those cookie sheets under it, and keep a mop and plenty of fresh water handy. I like to drain the radiator firstm then the drain plug on the one side of the block and the KS on the other.
Pete
Old Aug 23, 2007 | 01:15 PM
scottso's Avatar
Me too . When you do the WP its defies logic - each hose or bolt removed seems to produce more coolant .
I had read about removing the knock sensor - but after 11 years and 96K miles - shouldn't I be nervous that the threads are going to get screwed up? ...if I can remove it at all.
Has anyone had problems removing or reinstalling it?
Old Aug 23, 2007 | 02:10 PM
94Camaro_Z_28's Avatar
I drain the radiator and then just let it drain out of the bottom bolt holes in the water pump....I doubt there is a clean way to do it.
calaban
May 18, 2020 06:43 PM
Klypto
Mar 23, 2016 09:05 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
pologreen97z
Dec 2, 2014 10:42 AM
