Best way to check for spark?
Old Jun 11, 2005 | 11:24 AM
NVRLATE's Avatar
Since my cam install my car has not been running right. I replaced the opti because all indicators pointed to it being bad. What's the best way to check that spark is going from the opti to each plug?
Dave
Old Jun 11, 2005 | 11:35 AM
jkipp84's Avatar
Re: Best way to check for spark?
Try one of these. You can get them or something similar at Autozone, Advance, and the like for about $10. You can test the coil, each lead off the opti, and the plug wires with one of these. These things are worth their weight in gold!
Just set it up, disable the fuel, and have someone crank it over while you monitor the spark. Just an FYI on these - if the spark is not steady pulsing (more like sporadic), that equates to a no spark condition.
Old Jun 11, 2005 | 12:04 PM
NVRLATE's Avatar
Thanks. I never seen one of them before. Maybe it will shed some light on my engine woes.
Dave
Old Jun 11, 2005 | 02:39 PM
SBCGENII's Avatar
The part stores also have another one where you can adjust the gaps for differnt style ingnition's from points all the way to HEI and you just screw the screw out for the higher output ignitions and look for a good blue spark
greenzee28
Mar 26, 2015 09:13 AM
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
