Best valvetrain for cc503?
Old Dec 5, 2006 | 06:00 PM
snakeatinZ's Avatar
I tried the serch and came up empty. What are the best springs, locks, rockers, retainers, all of that stuff? Does anyone sell a nice package deal?
I would like to get parts that will work for a cc306 if I dont like the cc503.
ANY info would be greatly appriciated.
Thanks,
Steve
Old Dec 5, 2006 | 10:23 PM
matLT1's Avatar
Go to this page, it will tell you everything you need to know....
http://www.compcams.com/technical/Ca...07/168-169.pdf
Old Dec 7, 2006 | 05:49 AM
snakeatinZ's Avatar
I dont even see the cc503 on that page???
Anyone else? People who are running this cam what kind of set up do you have?
Thanks,
Steve
Old Dec 7, 2006 | 06:47 AM
huskersZ's Avatar
Check out the combination motorsports CM 612 spring kit....I think they are still offering, or go with comp 918's
Old Dec 7, 2006 | 07:09 AM
Steve0's Avatar
Look at that link again, it's the last cam listed under the "extreme energy" series on the first page. p/n 07-503-8. Page 2 tells you the match components.
Old Dec 7, 2006 | 07:16 AM
Javier97Z28's Avatar
Moderator
I ran CM612's for years, but I also know of people running comp 918's w/ 'em.
Old Dec 7, 2006 | 08:51 AM
Z-RATED94's Avatar
A set off 918's, Hi-Tech pushrods, 7/16 rocker studs, GMPP guideplates, and 1.6 Magnum NSA roller rockers should do the trick Steve.
Old Dec 7, 2006 | 11:27 AM
truedualws6's Avatar
Beehive Springs and Parts Info
If you go with the 26918 beehive springs. The retainers, locks and shims will
depend on what you want to do. If you use the stock spring seats then
the 7* hardware will work. If you want to use the Comp spring seats then
the 10* hardware with +.050" locks works the best. This is assuming that
you have stock heads.
Comp Press Release
If you want to go with 7 degree hardwarde:
787-16 retainers
648-16 locks
stock or LT4 spring seats
If you want to go with 10 degree hardware (super locks):
795-16 steel retainers, or
794-16 titanium retainers
611-16 locks (standard), or
614-16 locks (+.050)
4705-16 spring seats
Using the 7 degree hardware and stock spring seats you
should end up with an installed height close to 1.78". With
10 degree hardware, 4705-16 spring seats, and the +.050
super locks you should see a 1.75" installed height.
Many have used the stock or LT4 spring seats with these
springs. I personally don't like the way the springs sit on the
spring seat. I have the 10 degree setup on mine.
Here is a pic if you are curious Beehive and LT4 spring seat
HectorM52
Jul 30, 2017 11:46 AM
97SSdude
Aug 21, 2015 09:36 AM
alphaauto
Jul 26, 2015 04:40 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Wild1
Mar 26, 2003 06:48 PM
