best valve spring compressor
Old Oct 10, 2006 | 01:06 AM
Sporty-X's Avatar
I plan doing a cam swap soon. Any advice on what spring compressor to buy ? I want one easy to use for spring removal without taking the heads off.
Thanks.
Old Oct 10, 2006 | 09:59 AM
Guest47904's Avatar
Guest
Re: best valve spring compressor
This one is great for single spring applications.
http://buy1.snapon.com/catalog/item....re&dir=catalog
This one can handle SOME double springs but has trouble in the rear under the cowl.
http://www.lislecorp.com/tool_search...6750&Submit=GO
Do a search, this has been spoken about several times
Old Oct 10, 2006 | 11:46 AM
JasonK94Z's Avatar
This one is very good: http://www.ls1tech.com/forums/showthread.php?t=317675
Old Oct 10, 2006 | 12:14 PM
seawolf06's Avatar
I used that one for my 918's with the engine in the car. It wasn't nearly as hard as people make it out to be. There are some holes on the frame above the radiator that this will slide into when you take the handle off as well, making it easier to get the spring on there right.
Old Oct 12, 2006 | 10:12 PM
z275plus's Avatar
Thunderracing sells one that will do two springs at once and it works great.That is the one I used and didn't have a problem.
I think it was made by crane.
Old Oct 13, 2006 | 12:06 PM
Severous01's Avatar
SLP used to have one in their catalog that says you can swap springs without droping valves. or that you could change the springs with the head on the car....one way or another...and it was cheap, like 35 bucks.
the easiest i've seen though was for a head that was off the car. it's like a big c-clamp that clips onto the spring and sets on the valve. just pull the handle and it compresses the spring...remove the retainer clips and the unclip the tool....spring falls off basicly.
Old Oct 13, 2006 | 04:27 PM
speed_demon24's Avatar
Crane spring compressor, it made my spring swap easy as hell.
Old Oct 13, 2006 | 04:34 PM
JasonK94Z's Avatar
Just like the Crane except it does one spring at a time, and is only $30.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
