View Poll Results: Best thin LT1 head gasket for LE2 heads
GM Impala .029" thick
16
59.26%
Mr. Gasket .026" thick
11
40.74%
Voters: 27. You may not vote on this poll
Best "thin" LT1 head gasket...
Old Dec 30, 2006 | 07:40 AM
  #16
Joe B's Avatar
My 2 cents......."Supposedly" Mr Gasket is now packaging their 5716 gaskets sepperately and the packaging sticking issue is resolved(I hear)....but I really still prefer the Impala gaskets quality wise........and ofcourse the Cometics are the best of the bunch here, but the block and head surfaces should be at the right (cometic recomended) surfaced finish for them to seal best......this was more headache than it was worth for me, but that's just my opinion............Joe
Old Dec 30, 2006 | 10:36 AM
  #17
Wild1's Avatar
The Cometic H1656027S is not on their website. It must be a custom build. Is this a MLS gasket?
Old Dec 30, 2006 | 10:49 AM
  #18
wrd1972's Avatar
I see, they certainly are pricey at $150.00 plus.
I already have the Impala gaskets so it looks like I will just go that route. .003" one way or the other really does not seek to matter.
I read a few posts were a few claim they dont work well with aluminum heads, but then there are dozens of posts where people claim they have never had a problem.
Old Dec 30, 2006 | 08:56 PM
  #19
Wild1's Avatar
Just to be safe I'd re-torque the heads after it's first heat cycle. Some gasket companies state to torque once and leave it, but I like to edge on the safe side.
Old Dec 30, 2006 | 09:07 PM
  #20
wrd1972's Avatar
I do agree that this is good advice.
However the ones uder the valve covers are cake, but would you remove the headers just to get to those seven bolts or so?
Old Dec 30, 2006 | 09:54 PM
  #21
Joe B's Avatar
..the impala gaskets are designed for cast iron heads, but work well with aluminum also, it's just that the internal fire ring in the impala gaskets can brinel the aluminum head slightly around each cumbustion chamber......I would not re-torque them...you will just increase the brinneling effect and there is nothing to be gained from a re-torque
Old Dec 31, 2006 | 07:58 AM
  #22
wrd1972's Avatar
Joe,
Thanks for the information.
"Brinel" is now a new term in my vocabulary. What does this term mean as it relates to engine heads? Something like leaveing a ring like indentation?
Old Dec 31, 2006 | 05:59 PM
  #23
marshall93z's Avatar
Originally Posted by seawolf06
With aftermarket rods and pistons, you should have them .018 in the hole. The .026 head gasket will get you to .042 quench,
Not nit-picking, but that would be .044 quench.
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
