Best Street Head/Cam Package
Old Dec 8, 2003 | 01:17 AM
2FNFAST's Avatar
This will be used on a pretty stock LT1 for a while until I can afford more, will be used with stock intake, injectors, mainfolds, throttle body, etc. Only mods are K&N FIPK and a 3 inch cat back with high flow cats. Also will have a custom ECM by madz28.
Old Dec 8, 2003 | 02:15 AM
madwolf's Avatar
Looking at head porting reviews lately on here, I would say that Lloyd Elliot is the way to go, however, I'd also check http://www.advancedinduction.com
As for the cam, it all depends on what you're looking for. Driveability? Pass emissions? How high will you rev it? etc...
Old Dec 8, 2003 | 02:22 AM
S.J.S.'s Avatar
The "Good ole HotCam" my man. You can get the kit for 480.00 comes with springs and 1.6 rockers too. Good for the street.
Old Dec 8, 2003 | 06:57 AM
Fastbird93's Avatar
I'd say get a set of heads done, and then get a couple of cam recommendations based on the flowing characteristics of the heads. That way, you know there's going to be a good match. You don't need a cam lifting to .600 if your heads drop off at .550.
Old Dec 8, 2003 | 11:41 AM
Ai's Avatar
Ai
Best IMO will depend on what your goals are. If you don't have the $ to spend right now on tuning, a pile of misc. parts, etc. then I'd wait until you've saved ~$3k for it. The power is in the topend, so taking your time, saving pennies & researching options is likely your best bet, b/c mediocre stuff is going to get you mediocre results... & the bad thing is it wont be much cheaper.
For some more perspective, you might want to dig up a post from last week that Dennis (i forget his SN) made regarding flow #'s. There's some good information there for sure, b/c everyone has flow numbers, but only a few have decent dyno #'s .
Good luck
Old Dec 8, 2003 | 11:42 AM
Rival's Avatar
To make so power I would: Go to L.E for the heads, hands down. the port job with vavles is 1200 or 1300 and then combintation motorsports has a cam package for 600-700 with the xe grinds. I would either go with the 224/230 or the 230/236 if you wanted to get closer to 400rwhp(w/bolt ons and lt's). I would really buy some used lt headers your going to need them bad. You can find some for 4-500. Look and ebay and the in the for sale section. If you dont do headers then buy a cutout. A dyno tune with also be the best way to go when everything is done.
Old Dec 8, 2003 | 12:24 PM
FacelessZ's Avatar
Lloyd lives about an hour from me in Red Oak, Texas near Dallas. I can vouch for great work since I had a pair of fully ported LT1 heads in my hands and sold them in order to fund an engagement ring. The #'s were as follows:
.2 135/101
.3 188/136
.4 238/165
.5 265/184
.6 273/190
$1200 covered porting the heads, Ferrea 2.00/1.56 valves, Comp 987 springs, 10 degree retainers, locks, locators, seals, machining for seals and locators, milling, cleaning and assembly.
Old Dec 8, 2003 | 02:21 PM
BradZ28's Avatar
Do headers before or when you do the heads/cam package. I'm not even sure you would benefit from ported heads with a good exaust. Lloyd Elliot IMO is the way to go with porting your heads. Advanced Induction is making great power too. An XE grind by Comp is also a good choice IMO or a custom grind.
Brad
karpetcm
Aug 14, 2015 03:02 PM
4586
Aug 2, 2015 01:45 PM
realistyc
Jul 28, 2015 07:32 PM
jbc3
Jul 28, 2015 12:24 PM
