Best Stall for 224/230 @ 112LSA
Old May 4, 2006 | 10:09 PM
Eddie Z-28's Avatar
I was thinking about going with a Vig 2800. Just looking for other suggestions. Thanks.
Old May 5, 2006 | 01:15 AM
RedLT4Mike's Avatar
Re: Best Stall for 224/230 @ 112LSA
You seem to have done a lil' bit of homework.
If thats what you have decided on after research,
go with it, and don't look back. You know what you need
Old May 5, 2006 | 06:42 AM
chrism400's Avatar
I'd go for the 3200 with lock up of course. You won't be sorry, and street manners will be just fine - especially when it locks up. Don't be skeered of the stall!
Old May 5, 2006 | 07:12 AM
calfirebird's Avatar
I ran a 2800 with this verter and i run it on my 383 also awesome verter. but i would say any where from 2800-3200 would be nice.
Old May 5, 2006 | 08:04 AM
Bersaglieri's Avatar
Ask Javier, he's tweaked his 224/230 setup to perfection. I am pretty sure he's running a 3200 Vig, but started with a 2800.
-Dustin-
Old May 5, 2006 | 08:08 AM
Javier97Z28's Avatar
Moderator
Thanks Dustin...
The Vigi 2800 worked well with my 224/230, but I would 60' better with the 3200 Vigi stall in the long run. Look into some 3.73's as well.. it made a night and day difference w/ that cam from the 3.23's.
At this point the 3200 is too small for my LE3 cam.. time to go bigger!
Old May 5, 2006 | 08:24 AM
z275plus's Avatar
I would like to know that too.From what I have heard you can only go as high as a 2800 with a 95 with the obd 1 .
Old May 5, 2006 | 09:39 AM
Zigroid's Avatar
I have obd1 in my 94. I have a TCI super street fighter 3500 rpm stall that acts like a 4000 rpm stall. I have no problems with the "stall wall." If you do have problems you can have it tuned out. I had my pcm done by madz28 before I ran the stall.
oh yeah, and don't be afraid of some stall speed. prior to my car I had NEVER riden/driven anything with a high stall converter. I was scared at first but after driving it I absolutely love it. its a little bit of a pain going up long steep hills. when you stomp on the gas you will forget any problems of owning a high stall converter
javier: if I were you I'd look into installing a switch so you can lock the converter when you want to. my whole setup isnt too far from yours and my car locks up at 50 mph. this is around 1700-1800 rpm. I wouldn't really want it to lock up at anything lower than that. I have been wanting to install a switch so that around lower speeds (~35-50mph) I can keep it in 3rd gear and lock the converter manually. it gets to be a MAJOR pain when you get behind some dolt thats traveling at 48 mph and you can't get that extra 2 mph to lock up the converter!
Old May 5, 2006 | 10:21 AM
Honda Hunter's Avatar
Another vote for 3200.
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
