Best Stall for 224/230 @ 112LSA
Re: Best Stall for 224/230 @ 112LSA
Thanks Dustin...
The Vigi 2800 worked well with my 224/230, but I would 60' better with the 3200 Vigi stall in the long run. Look into some 3.73's as well.. it made a night and day difference w/ that cam from the 3.23's.
At this point the 3200 is too small for my LE3 cam.. time to go bigger!
Originally Posted by z275plus
I would like to know that too.From what I have heard you can only go as high as a 2800 with a 95 with the obd 1 .
oh yeah, and don't be afraid of some stall speed. prior to my car I had NEVER riden/driven anything with a high stall converter. I was scared at first but after driving it I absolutely love it. its a little bit of a pain going up long steep hills. when you stomp on the gas you will forget any problems of owning a high stall converter
javier: if I were you I'd look into installing a switch so you can lock the converter when you want to. my whole setup isnt too far from yours and my car locks up at 50 mph. this is around 1700-1800 rpm. I wouldn't really want it to lock up at anything lower than that. I have been wanting to install a switch so that around lower speeds (~35-50mph) I can keep it in 3rd gear and lock the converter manually. it gets to be a MAJOR pain when you get behind some dolt thats traveling at 48 mph and you can't get that extra 2 mph to lock up the converter!
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
