Best replacement parts?
Old Oct 24, 2008 | 06:09 AM
Savannah Dan's Avatar
I have one of my LT1’s torn down because of a blown head gasket. The oil pan filled with water/antifreeze so I wanted to give it a good look.
I’m going to replace the rings and probably the bearings (haven’t looked at them yet). What are the best replacement rings and bearings to use? Thanks for the help.
Old Oct 25, 2008 | 10:51 PM
Anybody?
Old Oct 26, 2008 | 02:24 AM
MachinistOne's Avatar
Clevite bearings - "P" series
Any of the rings out there will be fine, Sealed Power, Hastings, Perfect Circle, etc
I don't know how many miles you have on your motor, but I would advise against just replacing the rings in-frame. The rings that are in there are seated to the bore and you run the risk of the new rings not seating properly if you cannot put a new cross-hatch in the cylinders. Bearings are a good idea as the water eliminates the static lock of oil on the bearings and they may be hurt.
Old Oct 27, 2008 | 07:43 PM
I plan on using a bottle brush hone on it to get the cross-hatching.
Old Oct 27, 2008 | 08:02 PM
Not a good idea - you have no way of cleaning out all the metal particles that will be spread throughout the motor. We just had to rebuild a motor for a guy that did exactly this and wasted all his bearings and cam journals within 20 minutes of startup.
Old Oct 30, 2008 | 03:31 PM
I have the motor torn down. I'm going to wash it down after I hone it.
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Hurin
Dec 13, 2014 07:38 PM
