Best recommended intake gasket for port matched heads and intake
SCE - measure your port dimensions and get a set that is slightly smaller to trim up. Put a light coat of 3M weatherstrip adheasive on the heads and the gasket(around ports and water) apply the gasket and clamp the manifold down, let it sit overnight, then remove the manifold and trim the gaskets with a razor. Then put some silicone around the water openings and china wall - torque the manifold down and you are done.
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
