Best place to buy Cloyes double roller
Old Sep 9, 2004 | 08:02 PM
jays30thSS's Avatar
I have a 97 with vented opti and an EWP. I need a new timing chain for my 383. Can someone tell me where's the best place to buy one and what part number?
I understand I will need to remove the CPS reluctor wheel and find a 95 or earlier F-body crank hub also.
Old Sep 10, 2004 | 12:28 AM
turbo_Z's Avatar
Re: Best place to buy Cloyes double roller
Jegs used to have them. Do a search for the correct part number b/c only 1 works. If you cant find any info then I believe its just the 85+ SBC with HR cam.. runs about $70.
here is a link to the jegs webpage that list them all off.. you want the one with part number 3145.
Old Sep 10, 2004 | 02:19 AM
blwnlt4's Avatar
o'reillys carries cloyes timing chains/sets, if you talk to a decent parts guy and you get the right part # they should be able to get the set you want
Old Sep 16, 2004 | 11:04 AM
jays30thSS's Avatar
I found a "cloyes double roller timing chain" at O'Reilleys for $19.99
It says it fits 1955-1991 350 V8, among other things (including 305 V8 and a bunch of V6s also). It has two part numbers on it: C-3023XSP and C-3923XSP. Anybody know if this is the right one?
Old Sep 16, 2004 | 03:56 PM
jays30thSS's Avatar
Anybody know?
Old Sep 16, 2004 | 03:57 PM
turbo_Z's Avatar
No, you need the 3145.
DirtyDaveW
Mar 15, 2015 07:01 PM
nikolt1
Feb 27, 2015 09:10 PM
Queens94z28
Dec 20, 2014 09:11 PM
97 RedSS
Jun 10, 2003 07:58 PM
blue89iroc
Jul 18, 2002 03:35 PM
