Best Performance Cam for a Summer DD
Old Sep 27, 2006 | 10:29 PM
CamaroRacing12's Avatar
hey guys i want to cam my car but i have not the slightest i dea about cam's.... my LT1 is basiccly stock but if def gonna get the reg bolt on's in due time... i want a cam that will give me a lot of HP and have an amazing Idle sound... (i want people to know its cammed when they hear it lol) but it NEEDS to be awesome to drive with... i use my camaro as my DD during the summer but i dont drive too too much maybe 100 or so miles a week on average.... and advice and info on cams would be great..
also can only some cams handle nitrous? i am planning on a 100 shot down the road.
Old Sep 27, 2006 | 10:33 PM
zx1216's Avatar
Re: Best Performance Cam for a Summer DD
comp cams cc306, times are in sig, drives pretty close to stock with good tuning, if i can get it to hook its a high 11 sec car...
Old Sep 27, 2006 | 10:36 PM
Josh'95Z28conv's Avatar
Le4
Old Sep 28, 2006 | 08:30 AM
matLT1's Avatar
I have the 503 in my camaro. Very nice idle, no real loss in lowend but plenty of increased performance. Mileage is 17mpg at best, but if you want to play, you have to pay
Old Sep 28, 2006 | 09:58 AM
jsetzer's Avatar
Unless you have an absolute monster, you don't miss any power down low, just the curve is different so it feels like that. I made 340# by 2500rpm whereas on the stock cam I made quite a bit lower, but it peaked lower too.
Old Sep 28, 2006 | 01:57 PM
so the only thing that a big prformance cam kills is MPG? or will it hurtt he engine and transmisison during daily driving?
Old Sep 28, 2006 | 03:01 PM
matLT1's Avatar
Part of my mileage loss is due to the fact that I have 3.73 gears. The cam doesn't help either, but the gears do play a big part.
When ever you start adding significant power to a car, you are bound to wear parts out faster than they were designed for, especially if you "drive it like you stole it." When a powertrain piece in a car is designed, there are several things taken into account, one of which is the power that will be sent through it. If you start abusing it more than it was intended, exceeding its power capabilities, your are bound to break things or have to replace parts eventually. Its just part of the territory. Don't get me wrong, I have never been stranded or had troubles with my car, you just have to keep a closer eye on things and it is no longer as much of a "turn the key and go car."
Old Sep 28, 2006 | 03:36 PM
so would i be ok with a cc306?
Old Sep 28, 2006 | 03:41 PM
Bersaglieri's Avatar
I'd like to see these in your signature first.
1.6 RR's
E-WP
Longtube Headers
PCM Tune
Gears/Converter
Otherwise the cam will only be worth the sound it gives.
-Dustin-
Old Sep 28, 2006 | 04:21 PM
zx1216's Avatar
i get 23mpg on the hw with my cc306, its in the tunning and the 6-speed
Old Sep 28, 2006 | 06:46 PM
1.6 RR's
E-WP
Longtube Headers
PCM Tune
Gears/Converter
-Dustin-
i am planning on doing all that stuff first but i was just looking into the future on what i should get for my car.
Old Sep 28, 2006 | 09:37 PM
seawolf06's Avatar
The Crane 227 "baby cam" would probably be perfect for you. If you feel like you want a little more, check out the CC305 or CC503.
Old Sep 28, 2006 | 10:20 PM
NovaTodd's Avatar
I would say the LT4 HOT cam. I have it with a tune, shortie headers and have used it with 4.11, 3.73, 3.42, and 3.23 gears. The majority of the use as a DD was with 3.73 gears. Other than it could use a bit more converter, it works quite well. The A/C can be used without any problem and it doesn't heat-up in traffic.
You can tell the car has a cam but it is not a Pro Stock type idle.
Old Sep 28, 2006 | 10:50 PM
black97z28LT1's Avatar
Originally Posted by Josh'95Z28conv
Le4
Loyld Elliot has a stage 4 now???
Old Sep 29, 2006 | 12:01 AM
HardcoreRM125's Avatar
Yessir ... Havent seen any numbers yet, but its gotta be a ****in monster ...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
QuickSilver02
Apr 7, 2015 11:12 AM
