Best oil for Z28????
Re: Best oil for Z28????
fwiw I tried out the 0w40 Mobil1 on my last oil change and found my oil pressure has increased by 5-10 psi hot or cold. Also noticed the pressure is much more constant at WOT spurts than it used to be with the regular valvoline 5w30 I used to always use.
these 0w and 5w oils that start as mineral base stock are great if you wanna have the infamous lt1 spun bearing problems on high mileage cars. ill keep using 20w50(spring/fall) and sae 30(summer) and 10w30 in the cold.
Considering that the 0w and 5w are the viscosity's and not the thickness of the oil I suggest you should stop spreading bad rumors like this! I use German castrol 0w-30 in my car all year and it gives be better oil pressure hot or cold than Mobile 1 10w-30 or any other 10w-30 I have tried. JMO.
Originally Posted by captskin
Ditto.....10w30 in the winter, 5w30 summer....
no problems....
no problems....
http://theoildrop.server101.com/cgi/ultimatebb.cgi
M1 specifically 30wts. are too thin they are close to a 20wt. analysis PROVES that it is not the best choice for the LT1 and that 0w-30GC or 0w-40 M1 are better choices. Amsoils 30wts. are good choices too just not M1s 30wts. An oils ratings mean it falls in a weight range M1s oils tend to fall at the very thin end of the range and oil testing shows the LT1 likes thick 30wts to thin 40wts. You all want dyno and track numbers to back up[ performance mods yet you insist on ignorance with your oil. The analysis we speak of is like dynoing you oil it is actual testing to see how much wear metal is in there. The link above has lots of info including a whole section where people post the details of their car and it's use along with what oil and then the oils wear metal contents and measurements of how the oil itself is lasting. If you think you know more than that and are too pig headed to read and learn fine but don't try to tell others what is good because you are not educated enough to know what is good.
The General speced 5w-30 for CAFE reasons this same motor used in Europe or almost anywhere outside US and Canada specs 40wt., and GMs choice of M1 for the Vette was because they needed a synthetic for heat and Mobil was/is the biggest producer and you can bet GM and the others get something out of Mobil using them in advertizing too. M1 is good oil no doubt, the 30wts. just are not quite right for this motor.
