best oil filter
Old Oct 9, 2008 | 11:26 PM
firstlast's Avatar
best oil filter
i was wondering what kind of oil filters you guys prefer, im using a fram toughguard.
just chime in with what you are running and what your experiences are
Old Oct 9, 2008 | 11:40 PM
Fram is the last brand I would buy. They rate low in most comparisons I have seen. I am currently using a NAPA Gold(made by Wix). I use AC-Delco, too.
Old Oct 9, 2008 | 11:51 PM
silentsprintero's Avatar
+1 for Wix/NAPA Gold
Old Oct 10, 2008 | 02:57 AM
Green96Z's Avatar
I prefer the Purolator PureONE. I avoid Fram like the plague.
Old Oct 10, 2008 | 03:17 AM
SS RRR's Avatar
I've used AC Delco since the car was new. I've switched over to WIX.
Old Oct 10, 2008 | 09:42 AM
slomarao's Avatar
Baldwin here.
Old Oct 10, 2008 | 11:01 AM
n2ceptor's Avatar
Carquest part # 85060, Made by WIX...
Old Oct 10, 2008 | 11:56 AM
ABA383's Avatar
AC PF454 here...its the only one I have found that clears my big Kooks stepped 1 3/4"-1 7/8" headers...I have always liked AC filters...The K&N is nice too with the 1" bolt welded on the bottom for easy removal...
--Alan
Old Oct 10, 2008 | 12:04 PM
Connexion2005's Avatar
Wix...
6SpdLT1Z's Avatar
I've always used wix on the SS, used Delco on my '97 and '94 Z's though.
Only one I've heard bad things about is fram.
edit: Shoebox has already nailed it.
Old Oct 10, 2008 | 02:06 PM
Savannah Dan's Avatar
Originally Posted by green96z
i prefer the purolator pureone. I avoid fram like the plague.
^ +1
Old Oct 10, 2008 | 02:21 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
The Amsoil EaO series is a good filter. They also make a shorty that crosses to the PF454, although the Amsoil is a hair longer, perhaps 1/8". I have a couple, but have yet to put one on my car. It appears that it will fit with my Kooks, but my headers aren't stepped, if that makes a difference.
Old Oct 10, 2008 | 02:24 PM
Zaknafein's Avatar
Thumbs up
Stepped lose 1/16" of clearance... if you're that close then you've got bigger problems.
Chalk another Wix user up on the list.
Old Oct 10, 2008 | 02:49 PM
mdacton's Avatar
Wix racing
Wix/napa
car quest/purolator are the best.
delco is crap/cheapest you can get..... Motorcraft is a good filter too....
Look at the cage inside a delco its plastic.
Wix is the best
Old Oct 10, 2008 | 03:04 PM
Originally Posted by mdacton
Wix racing
Wix/napa
It's not cheaper than the Fram, which is cardboard.
