Best off shelf Cam?
Old Jul 27, 2006 | 09:50 PM
ProchargedLT1's Avatar
Best off shelf Cam?
A friend of mine is looking to buy a camshaft and needs some input. Here is a little info on the car..............
Its a 95 Z28 and the engine was just honed reusing stock pistons, new rings, bearings and upgraded the rod bolts to ARP's. The engine has mildly ported heads,intake and the usual bolt-on's...ie LT's, 58mm TB, Borla cat-back, 4.10 gear,6-speed and it weighs around 3300-3400lbs.
The RWHP #'s are not really as important as the track times so with that said he is looking for a cam that has pushed car's with similar mods into the 11's. Keep in mind this will be mostly a track car with a little street time. I know people are going to say go with a custom grind but he wants it to be an off the shelf hydraulic roller .
After a little researching it seems the CC306 has proven to push LT1 car's into the 11sec zone. What do you all suggest?
Thanks for any help!
Old Jul 27, 2006 | 10:07 PM
Javier97Z28's Avatar
Moderator
Re: Best off shelf Cam?
GM847? I'd choose that over a cc306 off the shelf.
Old Jul 27, 2006 | 10:09 PM
The 847 and 306 seemed to be the two most popular cams when doing a search.
Old Jul 27, 2006 | 10:11 PM
Moderator
XE 230/236 isn't a bad choice either.
Old Jul 27, 2006 | 10:19 PM
Klypto's Avatar
for ls1, i love the tr224-112
Old Jul 27, 2006 | 10:22 PM
Moderator
LS1 cams fit great in LT1's...
Old Jul 27, 2006 | 10:45 PM
seawolf06's Avatar
GM 847 if you insist on a off the shelf grind.
Old Jul 27, 2006 | 11:13 PM
arcticz28the383's Avatar
63-236/242-112
Comp Cams "Extreme" LT1 Camshaft, 236 / 242, .520 / .540 112 LSA, Very aggressive street/strip cam. Stroker engines, Heads, Headers, High Stall or M6, Gears, Computer Tuning Required.
This is the cam i have and I like it. I'd say its imbetween the cc306 and the gm847.
Old Jul 27, 2006 | 11:16 PM
http://www.thunderracing.com/catalog...&vid=4&pcid=51
Old Jul 28, 2006 | 08:53 AM
Well right now it looks like it will be the 847 or the TN233XL Camshaft 233/239
Old Jul 28, 2006 | 09:11 AM
GetaZforgetGT's Avatar
I had the 233/239 in my 350 and let me tell you it sounded awesome. Until I spun a rod bearing...
I am going to run it in my 383 also (should be done in the next week or so)but I don't know exactly what its going to sound like. It will obviously be much more tame but time will tell.
Clip of the GM847 idle in a 350 from Atljar's website:
http://www.s89572780.onlinehome.us/idle.wmv
Old Jul 28, 2006 | 09:15 AM
Victory Racing's Avatar
With as easy as it is to get a well thought and custom camshaft, thats the only way I would go. Comp Cams is usually a 2 day build time at most.
I have a grind I use 23x/24x 6xx/5xx 112LSA good cam makes gobs of power down low and pulls strong through the power band.
Old Jul 28, 2006 | 11:00 AM
jsetzer's Avatar
If I had it all to do ove again it would be LE3....
But for off the shelf gm847.
Didn't make any more tq than the cc306 for me, but it held the power band to a much higher rpm.
Old Jul 28, 2006 | 11:28 AM
SS RRR's Avatar
Ain't nothing wrong with an OTS grind as long as the heads are ported to accommodate.
Old Jul 28, 2006 | 11:57 AM
93redBirdMan's Avatar
Do you want to rev your motor past 6500 rpms?? If not, dont even think about the cc306 or the gm847...
