Best LT1 HEADS???
Old Aug 6, 2004 | 10:11 PM
bowtieforpower's Avatar
Best LT1 HEADS???
im looking for some good heads to put on my 96 z28. it has hooker cc lt's. lt4 hotcam kit, or pipe, borla exhaust, lpe intake, 373 gears. has anyone purchased heads or got their heads ported and had good gains for the $?. thanks.
Old Aug 6, 2004 | 10:57 PM
AZ2ENVY's Avatar
Re: Best LT1 HEADS???
One of the best out there is a set from Trick Flow . I know this personally
Old Aug 6, 2004 | 11:09 PM
dreamer1q's Avatar
You can always just buy mine
http://web.camaross.com/forums/showthread.php?t=289256
Old Aug 6, 2004 | 11:21 PM
LT1Squirrel's Avatar
depends on what youre gonna do....are you gonna stay stock CI and just do bolt ons with a low budget?...or are you going 400+ CI and need some heads that flow crazy up to 8000rpm?
Old Aug 7, 2004 | 01:35 AM
ZDriver96's Avatar
Best heads for an LT4 hotcam car are stock LT1 casting heads. Get them moderately ported to match the cam. Llyod or Phil can save u money and make sure your car rides out with the hotcam.
My first set of heads were from Llyod. Killer low price on the heads. They were moderatly ported with larger valves/valve job. Looked like he used a double cut and the exhaust wasnt polished and the intake wasnt really smoothed out. A budget head set up. He Did was would give me the most power on a budget price. I was running the xe230/236 112lsa. The car hauled ***. 2003-2004 Cobras got to see the "SLOW LT1's" tail lights.
I kept the LE heads but my frind Bob sponsered me and worked the heads to the max and the car's got more power now with the heads flowing 282cfms at .550.
I'd trust Llyod or Phil over the larger cylinder head companies.
Old Aug 7, 2004 | 02:02 AM
BigRedChevy's Avatar
www.airflowresearch.com arguebly the best set of heads on the market
Old Aug 7, 2004 | 02:20 AM
97WS6SCharged's Avatar
Buy a set of 18* Brodix heads and have Bret convert them to reverse cooling for you. Or you could do the Aaro 32v heads, but those aren't cheap.
Old Aug 7, 2004 | 07:12 AM
jkipp84's Avatar
I think that set dreamer1q is selling would be a great match to your set up and the bang for the buck would be very tough to beat.
Old Aug 7, 2004 | 07:18 AM
4drLT4's Avatar
Except for the fact that they were done by ARE, they should be fine.
ARE can't port heads to save their collective asses. Ask me how I know.
Old Aug 7, 2004 | 07:31 AM
jkipp84's Avatar
Ah, didn't know that.. Maybe some info from dreamer1q on what kind of power he made with them would help.
Another option in the same price range would be Lloyd Elliott's LE1 combo. $1100 gets heads and cam. I don't know what heads alone would cost...
Old Aug 7, 2004 | 09:42 AM
Ai's Avatar
Ai
Heads are where the power is at, but unfortunately you will get what you pay for in most cases. Without a budget, it's tough to suggest anything, as you can spend anywhere from $1000-3000 on worked over LT1's. The difference will primarily be in the quality of machinework and hours spent making all 8 cylinders consistent with each other. Without the facilities to do so, many simply can't keep their machinework under control, and without the $ to pay for the time, some may produce a decent initial test cylinder, but can't afford to actually duplicate it on the other 7 cylinders. Outlining a budget should probably be your first step
Old Aug 7, 2004 | 09:46 AM
Dave88LX's Avatar
Contact the guy above me. 'nuff said.
Old Aug 7, 2004 | 11:18 AM
SS MPSTR's Avatar
Best advice so far.
Old Aug 7, 2004 | 02:36 PM
96capricemgr's Avatar
Exept that they only recommend them(trickflows) for strokers or power adders because of the largerer than stock chamber that would drop compression on a stock shortblock. If you want to use them on a NA 350 and keep your compression you would need to do one or a combination of the following, new pistons, thin head gasket, mill the hell out of the heads.
My advise would be to use ported stock castings, I don't just look at the aftermarket and buy into all the advertizing so I am sure others will disagree.
Old Aug 7, 2004 | 08:12 PM
hey thanks for the advice guys, as for my price range, i am looking for anything up to 2000. thanks.
