Best hyd roller lifter for daily driver street/strip?
Hello all I have a question about which lifters to use in my new engine for my daily driver street/strip LT1, it's a na all forged 383 with ft pistons,splayed mains,the normal high performance mods ported heads & intake etc etc anyway which lifters are best suited to run up to 6500 - 6700 rpm?
I have a set of Comp R's but I've read alot of bad things about them so I've been looking at the GMPP racing lifters as used in the Caddy CTSV but I've heard they are noisy. I have Morels in another 383 I have but $550 is not in the budget for a set of those right now so what's the most relieable lifter on a budget? I also will be using the AFR hydra-rev kit if that makes any difference, I'm concerned about the lifters longevity and if they are noisy won't they cause tuning problems with the knock sensor?
I am doing a roller rocker upgrade and I am doing it once the right way. I have all new springs, retainers, locks, seals, rockers, pushrods, guideplates, studs and just about everything needed except lifters. I figure with 112,000 on the clock, it might be some safe insurance.
