Best Heads?
Old May 16, 2005 | 02:23 PM
69gto96z's Avatar
Question Best Heads?
If you are running an all motor application with headers, exhaust, and an intake, and you want to get a little bit more power from heads, what are some of the best brands to go with? What about if you plan to re-build and supercharge the LT1 later on? Anybody know?
Old May 16, 2005 | 02:24 PM
EKO's Avatar
EKO
Re: Best Heads?
AFRs are the best from what I hear. A bit pricey though.
Old May 16, 2005 | 04:34 PM
Mindgame's Avatar
Re: Best Heads?
The "best" is something you probably don't want to fork over your dollars for.
You have to figure out what your goals are first. If you want to build a 400-450rwhp normally aspirated engine then you can do that with the stock heads (people are doing it).
From 450+ rwhp I'd start looking to AFR or a converted gen 1 head.
For a blown engine, AFR has a nice thick deck and would probably be a wise choice for a high hp blower build, although a mild blower build could still work well with stock castings.
-Mindgame
Old May 16, 2005 | 05:24 PM
LameRandomName's Avatar
Re: Best Heads?
If you're asking what I think you're asking, consider the Edelbrock package.
Otherwise your choices start getting real wide. Not that that's a bad thing, but it'll call for you making a lot of decisions about things you probably never even thought of.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
