Best head gasket for 401ci lt1 ?
Old Dec 8, 2007 | 12:50 AM
  #16
BIGCOWL-IMP's Avatar
I`m just going to use a lt1 engine harness from a 95 z28
I think theres 2 companys that make headers for this swap but i can`t remember the other one. But the Kooks are the best they come with a plate that you bolt to the heads then you bolt the headers on. There a race header with 3 1/2 collector. I can change all the plugs in about 15 minutes and thats a big plus.
Old Dec 8, 2007 | 10:09 AM
  #17
FASTFATBOY's Avatar
Did you consider putting a carb on it? I have a super vic and the hole is already there.....no more opti.....all I would have to to then is buy the TCI 4L60E controller and the plate that bolts in place of the opti and a distributor.
I could buy a regular carb super vic and sell my EFI/elbow/monoblade setup.
Man my brain is burning up with this idea....my engine trans combo would run in the mid 10's on motor and low 9's on a 200 shot with overdrive!!
David
Old Dec 8, 2007 | 04:23 PM
  #18
Yes i did consider putting a carb on it and i still might if this ends up being to big of a headache. Yes i seen people useing the regular carb super vic intake but don`t you to modify the bolt holes or something ? Do you have more info or link with pics ?
Old Dec 8, 2007 | 04:55 PM
  #19
FASTFATBOY's Avatar
Well you would have to, I would not.
I stumbled on this, will it work for you?
http://app.infopia.com/Shop/Control/...d/0/rid/126348
David
Old Dec 8, 2007 | 04:57 PM
  #20
mdacton's Avatar
buy the super vic for a vortec, its like $270 bolt hole line up....go that route. EFI is junk.....it does not compare in a race car
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
