Best head gasket for 401ci lt1 ?
Old Dec 3, 2007 | 02:00 PM
BIGCOWL-IMP's Avatar
Its a 4.040 bore
I have been useing the fel-pro`s 1074 for the last few years and no problems but i noticed alot of guys useing the Cometic Head Gaskets and noticed there twice as exspensive. What makes them better if they are ?? Right now i`m right about 12:3 compression with the .039 felpro`s and the Cometic Head Gaskets are .027.
What would you guys use ?
I`m useing afr 220 heads etc etc with a nx maf system and i just bought the 2nd stage for that system so i might hit it with a 200-300 shot every now and then ?
Here`s a couple pics of my project
Old Dec 3, 2007 | 02:42 PM
Sparkz28ss's Avatar
I use 1074s on my blower motor...they work well for me.
that notch is sick, I bet the mustang guys are going to flip when they look under the hood.
Old Dec 3, 2007 | 02:58 PM
buzz12586's Avatar
What are you gonna run for ignition on that thing?
Old Dec 3, 2007 | 05:06 PM
kgkern01's Avatar
401ci with a 4.04 bore? That would mean a 3.91" crank?? 4.04 bore with a 3.875" crank gives a 397ci.
Old Dec 3, 2007 | 06:57 PM
mdacton's Avatar
cometics can be reused
I have used them 4-5 times with no problems.....1074's are one shot
Old Dec 3, 2007 | 09:28 PM
FASTFATBOY's Avatar
Cometic also has a different bore size, 1074 is a 4.125 bore. The Cometic is a 4.040 or a 4.100.
The heads and block HAVE to be setup for the Cometic or they will seep coolant.Has a certain Ra value, 50 or so I think.
Mine seeped and I trashed them.
I am thinking about a coupe chassis JUST like that.....man nothing like losing 500lbs like SNAP!
My drivetrain in that car, 10.60's all motor. I am seriously considering it.
You gonna have those Ford boys scratching their noggins!
David
Old Dec 3, 2007 | 10:50 PM
96ZCamaro's Avatar
Little off subject. But I am curious what you did for the headers on that car?
Old Dec 3, 2007 | 10:56 PM
FASTFATBOY's Avatar
I have been beating his brain up about this swap, K member is AJE, headers are Kooks made for this swap.
David
Old Dec 4, 2007 | 12:05 AM
SStrokerAce's Avatar
Ra has to be 30 or better, which is dam smooth in machining terms. Well not as smooth as a 1 Ra that you need for DLC coating but on a cast iron block or when you mill aluminum heads you need a lot of cutter speed and a slow feed rate. That and some copper gasket spray help seal them up. If you do all that there aren't many problems with the Cometics.
Bret
Old Dec 4, 2007 | 12:18 AM
marshall93z's Avatar
Sweet *** ride!!
Old Dec 4, 2007 | 01:31 AM
Thanks guys and ya i screwed up on the ci.
Looks like i will be sticking with the felpro`s
Ya its a AJE k-member for mustang for a sbc and if you switch the motor mounts from left to right side then you can bolt in a lsx motor. I also have the AJE th350 trans crossmember with the kooks race headers and everything bolted right in no problem.
This motor was in my 95 impala and went 10;82 with a 150 shot and now i`m about 1,400- 1,500 less wieght
Old Dec 4, 2007 | 04:57 AM
94FBIRD's Avatar
CRICKEY! Nice project. Me likeey.
Old Dec 4, 2007 | 08:24 AM
Z-RATED94's Avatar
Wow, what a weight reduction. So is it ok to spray a second shot, for a total of 300hp through the NX maf kit? I'm asking for future reference.
Old Dec 5, 2007 | 02:50 AM
I don`t think i will hit it with a 300 shot but maybe a 250 ?
Motor should handle it.
Callies crank
Callies splayed main caps
Oliver billet rods
True JE Custom Pistons $$$$
I can`t wait to fire this thing up
Old Dec 7, 2007 | 01:17 PM
FASTFATBOY's Avatar
BIGCOWL, who's wiring harness did you use to run it? Are Kooks the only ones who make headers for that swap?
David
