Best Gaskets?
Old Jan 6, 2008 | 06:02 PM
OutsiderIROC-Z's Avatar
Best Gaskets?
I am going to have to remove the head on my 95 Z28 to extract a couple broken exhaust bolts. Couple questions.
Are there any little tricks or snags on these engines that I should watch out for?
and
What brand of gaskets would be recommmended for the intake and head, and where is the best place to get them?
Thanks in advance.
Old Jan 6, 2008 | 06:07 PM
96capricemgr's Avatar
How do you define "best"?
I would recommend something thinner than stock or Felpro.
Victor Rienz has a nice .026 worth some compression seeing as stock is .049 and Felpro is .039.
Felpro intake gasket kit is nicely priced and complete.
Old Jan 6, 2008 | 06:28 PM
dangalla's Avatar
i would use a factory gm gasket, i think the impala gasket is .029 which like stated is worth some compression over the stocker
Old Jan 6, 2008 | 07:57 PM
Wild1's Avatar
Mr. Gasket sells a pair of Multi-Layered Steel gaskets with a compressed thickness of .026. They look pretty good and I ordered me a set. I'll let you know. Summit sells them by the pair.
Old Jan 6, 2008 | 08:35 PM
The Mr. Gaskets doubled in price at Summit because of packaging QC issues costing them a LOT of free replacements. The Victor Rienz I recommended are the same gasket at a much lower price and without any packaging hassles. PN 5898 I paid $22 apiece at NAPA
Old Jan 6, 2008 | 09:28 PM
I think I will go ahead go with the GM gaskets for the Camaro.
Where do I find part numbers? Thanks again.
Old Jan 6, 2008 | 09:31 PM
Viper's Avatar
I would stick with the GM gaskets also...........
Viper
Old Jan 6, 2008 | 09:34 PM
cnorton's Avatar
Head gasket
GM head gasket - # 10168457
Old Jan 7, 2008 | 07:54 AM
BlackScreaminMachine's Avatar
Ive always used LT4 head gaskets.
Old Jan 7, 2008 | 08:33 AM
aboatguy's Avatar
If your just replacing the Headgaskets without and resurfacing the LT4 gaskets a good choice
For a new shortblock/ heads package I like the Cometic MLS' gaskets. I've been using them for a while and they havent failed me yet(although other stuff has)
Old Jan 7, 2008 | 10:24 AM
Stl94LT1's Avatar
GM Impala SS .029 head gasket. Part # 12553160
Old Jan 7, 2008 | 12:51 PM
MrCamu's Avatar
I would go with the felpro and put on them some "hylomar" spray gasketglue.
Old Jan 7, 2008 | 01:32 PM
dangalla's Avatar
i would avoid this, i was always told to never put anything on a headgasket. maybe something has changed since then and i am sure someone will correct me
Old Jan 7, 2008 | 01:48 PM
MrCamu's Avatar
Yes, I know that head gaskets don't need/never put any extra glue or RTV, but the hylomar don't do any harm to the head gasket it only tightens and ensures better the seam, but you don't have to use it if you don't wanna
Old Jan 8, 2008 | 09:05 PM
z275plus's Avatar
I 2nd the Victor Rienz gasket, A lot of racers use them and they work great.
