Best Crankshaft Forged for $1200-1300
Old May 20, 2004 | 05:27 PM
Highlander's Avatar
Hello guys...
after doing a search it was a bit hard to find out about one of the best crankshafts out there...
I called callies and they have Racemaster out of stock till 5 weeks or so...
I know that the 5 weeks means 5 months from the manufacturers point of view... as all I have ordered has taken more than 5x the advertised time to deliver...
The callies racemaster is not available.. I was wondering what other crank is comparable to that one, AMERICAN MADE, for the same price range...
I was thinking of lunati as it has been a proven combo, but after looking at some searches I haven't found out much about it...
let me know what you guys think and your order of preference for cranks.
Old May 20, 2004 | 06:05 PM
disco192's Avatar
what about a cola crank?
Are you looking for strong or lightweight?
Old May 20, 2004 | 06:15 PM
SS MPSTR's Avatar
Scat makes a nice crank. I have a Scat in both strokers.
Old May 20, 2004 | 06:31 PM
Highlander's Avatar
A bit of both maybe... I am looking more at strength... so they say that there is nothing like a free lunch... i guess 49-50lbs not more than that which is what the callies crank weighs...
I haven't heard much about cola other than a few posts but I know the racemaster is liked a lot.. the other thing would be to shell out $1k more for a magnum crank, which i dont want to spend really.. i think the racemaster series or similar crank is more than enough for 1000-1100 hp crank range...
I want to get 700rwhp @ 6500rpm or so... I dont think I will have a problem with that goal but If i EVER, which i hope not, want to crank up the notch, all i want to do is put better fuel and a smaller pulley on the YSi.
Old May 20, 2004 | 06:35 PM
Grover's Avatar
Won't the Callies Dragonslayer handle that kind of power? That's the one I was thinking of using for similar goals.
Old May 20, 2004 | 06:45 PM
SStrokerAce's Avatar
Most 4340 forged cranks will handle 700rwhp easy. No need to spend lots of money on the crank here. I would rather spend it on rods and rob bolts along with block prep.
A Scat forged crank would work great here, and that's about $650 or so.
Remember it's not just power that breaks cranks, it's RPM and you are probably going to keep it below 7K. On top of that why would you want to get a crank that is stronger than the block? A 1,000HP crank is not going to survive a main bearing failure due to cap walk, so might as well not spend the money there.
Bret
Highlander's Avatar
The dragonslayer will hold but I wanted the racemaster for extra security, which i know is a better crank..
they do have the magnum... I really would love a callies but not sure now...
Was thinking on lunati but I have read not so good stories with it and I am not sure...
Looking for some people to chime in...
Old May 20, 2004 | 07:02 PM
Highlander's Avatar
Bret
Hm.. that is interesting... I thought the main caps would pose a problem if the RPM was extensive.. might as well keep the eagle crank i have then?
The thnig is that i want to be able to have the ability to crank the boost at will at any given point and have a crank that supports the power.. I believe that the eagle rods are more capable than the eagle crank given the l19 rod bolts im putting in...
So wanted a Racemaster for that reason.. the dragonslayer is also backordered and I believe the difference between the eagle and the dragonslayer is not something to be considered all the $ and hassle... Not sure.. just here to STILL learn....
Old May 20, 2004 | 07:13 PM
Yeah the Eagle will be enough.
I know people like the Callies cranks and they do make a awesome piece but once the main cap starts moving around the first thing it takes with it is the crankshaft.
Bret
Old May 20, 2004 | 07:17 PM
Highlander's Avatar
well.. then the rod bolt change is the only thing that is in order.. i might do the 2ble keyway on the crank at this point then...
What about higher powers than 700rwhp with the eagle? i do know that intimd8 has done 868rwhp!!!!
You once said that eagle at those power levels were on borrowed time...
Let me know
THanks
Old May 20, 2004 | 07:25 PM
I have two motors in the shop now that are using a Eagle 4340 in them and both will easily do 750-800hp and I am comfortable with them in those motors.
Bret
Old May 20, 2004 | 08:33 PM
rskrause's Avatar
Moderator
The "Dragonslayer" would be fine.
Rich Krause
Old May 20, 2004 | 08:43 PM
my94blackz's Avatar
Another vote on the Eagle.
Old May 20, 2004 | 09:12 PM
Highlander's Avatar
The dragonslayer is only available for 6" rods... so same 5 freaking week wait...
but for the price difference I go for the racemaster...
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
Catmaigne
Jul 14, 2015 05:17 PM
mrwz28
Jul 8, 2015 09:11 PM
