Best cam specs for a LT1 M6 for NA/N20 custom grind?
Old Sep 22, 2003 | 08:16 PM
fireturd's Avatar
We are looking to figure out what would be the best cam specs for a 1996 LT1 M6 car with the desire to have good gains over the HOT Cam thats in there now with the following mods.
LT4intake,Hooker LT's, 4in Ypipe, cutout, MSD ignition,NXwet kit, 3.73 gears, Ram Air, Ported MAF, MAFT, 58MM TB, 1.6 roller rockers,your usual bolt ons and had a HOT CAM and aftermarket springs.
Now he wants to step up to the 150shot and go for a cam that will get some good gains over that GM hot cam. We are looking around and not finding alot of cam choices for the stock headed LT1 that wants good gains with over the previous cam NA and on N20. Car puts down 352RWHP and 359RWTQ NA and 450RWHP and 487RWTQ on the 100shot.
He would like an idea of doing a custom ground cam that would work well, and be streetable. Fuel economy who cares, loud who cares. Would like an approx 6300-6600RPM Peak,
Old Sep 22, 2003 | 10:37 PM
Smoke T/A's Avatar
How bout a 236/245 .555/.576 w/1.6 115lsa +3 xe grind from combo motor sports??? Peak rpm in a 350 would be about 6600. HTH
Joe
Old Sep 22, 2003 | 11:39 PM
Kreinmc's Avatar
cc306 :P
Old Sep 22, 2003 | 11:50 PM
Z97LT1's Avatar
XE 224/236 114 ls
Old Sep 23, 2003 | 03:25 AM
SStrokerAce's Avatar
Guys would be suprised what a big LSA cam will do on N2O in this duration level. When you get into large duration cams that's when the larger LSA helps.
The right nitrous cam will be worth about 35-40hp over the Hot Cam on the bottle and about 25hp off the bottle.
The right N2O cam will not be the best cam for a NA motor.
Bret
Old Sep 24, 2003 | 07:06 AM
fireturd's Avatar
How about saying lift when you put up the #'s too and where to buy that cam Help a guy out here! LOL!
Old Sep 24, 2003 | 07:17 AM
Cmr0z28's Avatar
www.cmotorsports.com
Old Sep 24, 2003 | 11:02 AM
ShelbyZ28's Avatar
Agreed. Give Combo a call they know their stuff . They will hook you up with exactly what you want/need for your application
Bryan
Old Sep 25, 2003 | 09:40 AM
fireturd's Avatar
I'll have to check them out seems they have some nice grinds there.
Someone school me a little bit and tell me this on cams.
I understand lift and Lobe seperation ok.
Duration i'm a little fuzzy on. Why a higher or lower duration and whats this doing??? Thanks for throwing a few syllables out there for the greater part of my stupidity.LOL!
Noenav
Mar 1, 2019 07:38 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
thenewkid
Nov 27, 2014 09:41 AM
1LEThumper
Jul 14, 2003 12:45 PM
Burn_Out
Aug 18, 2002 08:49 AM
