I have this anyoing chirping noise coming from the main drive belt in the engine. It happens more when the car is warm.
Any ideas as to what it may be/fixes ? I'm not sure if it's a pulley or the belt itself. To me it seems higher up, in around the altenator.
Mine was doing that, I would spray some belt dressing on it and it would stop for about five minutes. I had the original belt on it '97, though it only had 16k miles on it. I went ahead and got a new belt and so far no squeeks. I got the Gatorback belt from Autozone for $20 (Goodyear wanted like $60 for the same belt).
It does it all the time (driving/ideling). If it's cold, when you first start it up it doesn't chirp.
All try one of those gator belts. How hard is it to get that belt off ? Any special tools ?
Just put a socket wrench on the tensioner at the bottom, turn clockwise to remove the tension from the belt, and pull the belt off.Originally posted by 96TransamConvt
Thanks guys,
I will give it a try this weekend.
