belt size for ile ac delete pully?
Old Aug 12, 2005 | 08:31 PM
1FASASZ's Avatar
does anybody know the belt size for ile ac delete pully?
Old Aug 12, 2005 | 08:33 PM
v8pwrdz28's Avatar
Re: belt size for ile ac delete pully?
i believe with the AC delete pully u keep the stock belt length.
Old Aug 12, 2005 | 08:37 PM
1FASASZ's Avatar
oh ok, i assumed i would need a smaller belt since the delete pully is alot smaller than the original
Old Aug 12, 2005 | 09:52 PM
Tonedef's Avatar
I believe the belt is smaller, I just sent you a pm....
Old Aug 12, 2005 | 09:57 PM
v8pwrdz28's Avatar
i thought the AC delete pulley was the same size and just replaced the AC, i didnt know it was smaller.
Old Aug 12, 2005 | 10:37 PM
94 TA TT2S's Avatar
It will work but you really need to get a belt an inch shorter than stock works better, stock size has a bit of slack in it.....
Old Aug 13, 2005 | 02:40 AM
Lower's Avatar
Personally, I would do the swap, and then debate if you need a different belt.
I say this because having done the swap, it looks like your ability to use the same belt or the need to use a different belt is going to vary wildly, with no ryhme or reason to the make, model or year.
Some report needing a different belt, and some report not needing one.
Good luck!
Old Aug 13, 2005 | 07:50 AM
Bawls's Avatar
Too weird, I have the 1LE pulley, and a stock length belt with no issues with slack. Feels just as tight as when I had the a/c compressor's pulley.
Old Aug 13, 2005 | 08:19 AM
There were two different compressor pulleys (early and late design). Two different diameters. The a/c delete pulley comes in only one size. That's why some say the original belt will fit, while others say it won't.
Old Aug 13, 2005 | 12:59 PM
94zgreenmachine's Avatar
I was having this problem with belts being thrown/shredding. While that problem is fixed, I went to the dealer for some answers on this same question. They have a first design belt and second design belt, just as shoebox has said about pulley size. The difference between the two is approx. 20mm which is not all that much. Both belts fit as I shredded the shorter belt prior to me fixing the problem. I have since gone back to the longer belt with no problems but I do carry a spare belt
Old Aug 13, 2005 | 02:24 PM
1FASASZ's Avatar
i put on the stock belt, and it seems to be fine. i have about 100 miles on it with no problems
HectorM52
Jul 30, 2017 11:46 AM
Jason Short
Jan 19, 2015 06:34 PM
Snoman73
Nov 17, 2014 07:22 PM
